X555ld rev 3.3
  • scolfield035
    • Sep 2017
    • 7
    • TÜRKİYE
    X555ld rev 3.3
    X555ld rev 3.3
    nvdia 940m - n16s-gt-s-a2
    bİos ? Help me !
  • holz.dl
    • Apr 2017
    • Brasil
    Re: X555ld rev 3.3
    i need this bios
      • 20938
      Re: X555ld rev 3.3
      Originally posted by holz.dl
      i need this bios
      https://www.badcaps.net/forum/showth...id=8&styleid=7
      • hallmark1730
        • Apr 2021
        • 27
        Re: X555ld rev 3.3
        please help ineed bios
          • 20938
          Re: X555ld rev 3.3
          https://www.badcaps.net/forum/showth...ghlight=X555ld
          • hallmark1730
            • Apr 2021
            • 27
            Re: X555ld rev 3.3
            thank u i will try but not workink.my motherboard x555ld rev 3.3 n16s-gt-s-a2 nvidia cards not working
              • 20938
              Re: X555ld rev 3.3
              https://www.badcaps.net/forum/showth...ghlight=x555ld
              • hallmark1730
                • Apr 2021
                • 27
                Re: X555ld rev 3.3
                hi again i try before this bios but winflash message bios file is not valid.
                this vram chip is n15 but i need n16s please help me
                  • 20938
                  Re: X555ld rev 3.3
                  Post your original bios backup and post a good readable picture of the white/green sticker with the barcode/QR code on it .Its best to program the bios with an spi programmer if you have one. Winflash does have a force option though .
                  • hallmark1730
                    • Apr 2021
                    • 27
                    Re: X555ld rev 3.3
                    Hello I added photos and bios.This is the bios file that asus accepts and installs with its own program.and i added the latest version 307
                      • 20938
                      Re: X555ld rev 3.3
                      Post YOUR bios backup,the one on the bios chip.Use an SPI programmer to backup, need the whole 8MB ,not updates.
                      • hallmark1730
                        • Apr 2021
                        • 27
                        Re: X555ld rev 3.3
                        i dont have a spi programmer please different way?
                        i crate backup for bios backup toolkit v2
                        • hallmark1730
                          • Apr 2021
                          • 27
                          Re: X555ld rev 3.3
                          can i use this. i will buy
                          • hallmark1730
                            • Apr 2021
                            • 27
                            Re: Asus main board : X555ld rev 2.0 & rev 3.3 & rev 3.6 bios
                            hello friends
                            asus x555LD rev.3.3(Case code:k555lb)but inside bios x555lbd.307(i think wrong bios)
                            n16s-gt-s-a2 nvidia chip inside.intel gpu work fine but gt940m is code 43 ?
                            please help me
                              • 20938
                              Re: X555ld rev 3.3
                              Sure,if other methods to flash don`t work.The CH341A black pcb version might need modifying. Check if its output is 5V on pin 28,if so then do the 3.3V mod - https://www.chucknemeth.com/usb-devi.../3v-ch341a-mod ,there are youtube videos too and lots of other info about the mod if you search
                                • 20938
                                hello friends
                                please help me
                                (334) X555LB on the white sticker is the bios that the board shipped with. So you need a X555LB bios
                                  • 20938
                                  Re: X555ld rev 3.3
                                  Try the attached bios,flash with AFUwin from here - https://www.ami.com/download/aptio-v...pdate-utility/
                                  • hallmark1730
                                    • Apr 2021
                                    • 27
                                    Re: X555ld rev 3.3
                                    Hi again i received programmer(yes black pcb). created backup add here.I tried to write from ami before but bios did not accept it because it shows 306 ldb
                                      • 20938
                                      Re: X555ld rev 3.3
                                      see posts 15 and 17 .The bios at post 17 has your DMI + win key added .
                                      Use neoprogrammer or asprogrammer software
                                      https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
                                      https://www.badcaps.net/forum/showpo...6&postcount=10 AsProgrammer
                                        • 20938
                                        Re: X555ld rev 3.3
                                        The backup is not good,its corrupted, theres a few reasons for it.
                                        The clip isn`t held on steady or its not making good contact.
                                        The 3.3V volt mod hasn`t been done
                                        The default software is shit
