Macbook A1707 820-00928-A bios dump needed...
  • andrew25
    • Feb 2016
    • 223
    • Malawi
    macbook A1707 touchbar bios dump urgently needed... board ID: 820-00928-A
  • quala
    • Mar 2014
    • 5
    • israel
    Re: Macbook A1707 bios dump needed...
    http://www.mediafire.com/file/j8clo8...7-UNLOCKED.BIN
    • andrew25
      • Feb 2016
      • 223
      • Malawi
      Thankx bro
      • quala
        • Mar 2014
        • 5
        • israel
        you are welcome
        if you have locked bios ..post here
        • bluestone
          • Jun 2011
          • 343
          • Ghana
          I need the bios chip location
          • macfactory
            • Sep 2017
            • 3
            • CHILE
            because the macbook when flashing the bios, is leaving very slow?
            • macfactory
              • Sep 2017
              • 3
              • CHILE
              Why the macbook when flashing the bios, is starting very slow?
              • begemot80
                • Nov 2018
                • 7
                Hi, anyone has bios for macbook pro A1707 touch bar board ID: 820-00281-A ?
                • DARZO
                  • May 2017
                  • 14
                  • chile
                  this file at startup asks for 6-digit code
                  • interpc
                    • Feb 2015
                    • 74
                    • Mexico
                    works!!!
                    • Stephen
                      Meow Meow MEOW!
                      • Apr 2020
                      • 674
                      I noticed this as well. Got a SYSTEM PIN request for this BIOS
                      sigpic
                      MEOWING IN THE IMPOSSIBLE UNIVERSE!
                      • APPLECLINIK
                        • Dec 2018
                        • 5
                        • ITALY
                        hello brothers is it possible to clean ME of this bios? 820-00928 macbook pro, thanks
                        • vzrivpaket
                          • Jun 2017
                          • 11
                          • Poland
                          try.
                          • patocodu
                            • Sep 2014
                            • 8
                            • ecuador
                            Hi, can you help me pls, this bios is locked , i need to unlock it 820-00928-A, Thanks So much
                            • peste
                              • Dec 2016
                              • 13201
                              • ROMANIA
                              try..
                              • klean
                                • Feb 2020
                                • 37
                                • Albania
                                hey hello can you help me to clean this bios ??
                                • DanielDacko
                                  • Mar 2015
                                  • 325
                                  • Macedonia
                                  Password removed and ME cleared. But the file is kinda strange, try and report.
                                  I don't provide help for people using CH341A and a clip.
                                  • klean
                                    • Feb 2020
                                    • 37
                                    • Albania
                                    hello shqipe, now capslook turn on when i pres but turn off after few seconds.
                                    • fricosu007
                                      • Feb 2016
                                      • 29
                                      • romania
                                      A1707 Clean ME
                                      could someone help me clean ME region on this macbook pro A1707, i already tried 3 times and it seams i am failing ... either not booting or booting very slow or update error when trying to update BigSur or Monterey and i am pretty sure it messed up after some crap update, main issue on this board was PCH short on 3v or 1v line i don't remember, i replaced the PCH an year ago and all went smooth until the first update. Many thanks !
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12108
                                        Re: A1707 Clean ME
                                        Clear ME doesn't solve the problem, try to fix bios again.
                                        I have cleared ME your file but the error is still not resolved (try with higher ME version same result)
                                        • CG_Dionysos
                                          MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
                                          by CG_Dionysos
                                          I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
                                          • Model: A1707
                                          • 15-inch, Mid 2017
                                          • 3.1 GHz Core i7
                                          • 16 GB RAM
                                          • Radeon Pro 560
                                          • 1 TB SSD
                                          • Board number: 820-00928-A
                                          I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
                                          Thanks in advance!
                                          Greetings from Germany...
                                          09-16-2025, 06:43 AM
                                        • leonemax81
                                          Macbook a1707 820-00281 Battery no Power
                                          by leonemax81
                                          Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                                          08-23-2024, 09:24 AM
                                        • re-atari
                                          Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
                                          by re-atari
                                          Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
                                          Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
                                          02-03-2025, 06:49 PM
                                        • sofles
                                          Macbook a1707 2017 model 820-00928 GPU issue
                                          by sofles
                                          Hello there
                                          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                          11-21-2024, 05:25 AM
                                        • jesi
                                          MacBook Pro 820-00281-A A1707 macbook
                                          by jesi
                                          hi all techs
                                          require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
                                          adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
                                          update:
                                          when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
                                          08-23-2025, 02:35 PM
