Asus x70i bios
  • kadi144
    • Aug 2015
    • 690
    • algerie
    Asus x70i bios
    hi guys
    i need a ASUS X70I bios
    th board is
    K51IO REV 2.1
    thanks
  • kadi144
    • Aug 2015
    • 690
    • algerie
    Re: Asus x70i bios
    Here is my original dump
    please i need it
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      Re: Asus x70i bios
      good luck
      Im Back... sort of...
      • kadi144
        • Aug 2015
        • 690
        • algerie
        Re: Asus x70i bios
        Originally posted by ala_borbe
        good luck
        thanks
        i will try it and reply
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
