Lifebook NH532 Bios clean
  • quic307
    • Jun 2015
    • 255
    • Greece
    I have the Lifebook NH532 (napa rev 2.1) bios which is lock.
    Does anyone has dump bios?
    I attached the bios.
  • String2016
    • Nov 2015
    • 2233
    • philippines
    Re: Lifebook NH532 Bios clean
    Here is you bios from paid site give feed back if its working
    • quic307
      • Jun 2015
      • 255
      • Greece
      It doesn't work to me. Probable it's not the same motherboard.
      Thanks...
      • quic307
        • Jun 2015
        • 255
        • Greece
        I fixed the bios and I made them from the beginning for two different motherboard.
        They works to me ...
        • 10000000
          • Jul 2020
          • finland
          Thanks, 114 was working for me.
          Broken laptop power connector destroy my mx100 ssd and scramble bios.
          Flash was w25q64cv and programmer tl866 IIplus.
          Check id must disable and not sure but, finally i keep power on pcb when program chip. I use clip connector.
          • TacticalFahrrad
            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
            by TacticalFahrrad
            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
            06-30-2025, 04:09 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • DynaxSC
            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
            by DynaxSC
            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
            11-06-2022, 05:22 PM
          • f-bone
            Asus K513E no image, bios dump attached
            by f-bone
            Hi guys!
            I have this laptop which is turning on but has no image. I have attached the bios dump but I can't seem to find a working one. I also read a similar thread mentioning WBT.exe v314 but no instructions on how to use that.
            Can you please help me with a working binary that includes the DMI info from my dump? Or kick me to the right direction to try and add the DMI section myself? I used HxD on my dump and found the serial on multiple places so I am not sure what to copy.
            thank you very much in advance!
            br,
            george...
            07-04-2023, 02:27 AM
