Lifebook NH532 Bios clean
  • quic307
    • Jun 2015
    • 255
    • Greece
    I have the Lifebook NH532 (napa rev 2.1) bios which is lock.
    Does anyone has dump bios?
    I attached the bios.
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: Lifebook NH532 Bios clean
    Here is you bios from paid site give feed back if its working
    • quic307
      • Jun 2015
      • 255
      • Greece
      It doesn't work to me. Probable it's not the same motherboard.
      Thanks...
      • quic307
        • Jun 2015
        • 255
        • Greece
        I fixed the bios and I made them from the beginning for two different motherboard.
        They works to me ...
        • 10000000
          • Jul 2020
          • finland
          Thanks, 114 was working for me.
          Broken laptop power connector destroy my mx100 ssd and scramble bios.
          Flash was w25q64cv and programmer tl866 IIplus.
          Check id must disable and not sure but, finally i keep power on pcb when program chip. I use clip connector.
          • TacticalFahrrad
            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
            by TacticalFahrrad
            I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
            BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
            06-30-2025, 04:09 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • MDSI
            HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
            by MDSI
            I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
            Details:
            Model : HP OMEN 17-an012nf
            Motherboard Part Number : DAG3BAMBAF0 REV : F
            Serial Number (S/N) : 5CD7280D51
            BIOS chip : Winbond W25Q64VSIQ
            Programmer : EZP2023+
            Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
            I already...
            07-28-2025, 07:11 AM
