HP Probook 440 G4 Working BIOS
  • hoaca388
    Badcaps
    • Jan 2022
    • 12278
    #81
    Originally posted by mohamedelmasry
    5cd7354rv8
    Post in the right place.
    • Eng MoamenAtef
      • Mar 2025
      • UAE
      #82
      Thank you for your interest
      • PacoGT
        • Sep 2022
        • 105
        • Guatemala
        #83
        Originally posted by biospwd
        Re: HP Probook 440 G4 Working BIOS
        Check this, should works.
        i download this file in one laptop hp, and turn on buy display is 30 sec.
        and the power off for windows, dont shut down complete, the led of power button is still on
        and i dont have the original bios because other person is erase complete the chip of bios
        can you give me a bios clean for mi laptop?¡
        • peste
          • 13439
          • ROMANIA
          #84
          post S/N, full name and model, motherboard model, product number,etc.
          • PacoGT
            • Sep 2022
            • 105
            • Guatemala
            #85
            Hp probook 440 G4
            DA0X81MB6E0 REV E
            s/n 5CD7050Y9X
            the motherboard dont have gpu aditional
            • PacoGT
              • Sep 2022
              • 105
              • Guatemala
              #86
              Hp probook 440 G4
              DA0X81MB6E0 REV E
              s/n 5CD7050Y9X
              HELLO friends, seeing that many had problems and I tried the bios here and they all had the same problem,
              which is 30 seconds to turn on, or the laptop does not turn off or does not suspend it stays with a black screen,
              that happened to me with the bios, the problem with the laptop that I have is that a person erased the chip completely
              and did not leave a backup of the original, so after 2 days of testing and testing I found the solution, I leave here the copy
              of the bios that I managed to create, these bios are completely blank, you will have to manually enter all the information
              of the ID, serial, etc. The equipment is currently giving an image 2-6 seconds after turning on, I tell you that I used the P91 build
              since the P85 gives the problem that it takes a long time to give an image, it does not turn off, or it does not turn on, or the fan stays on full blast,
              as I see or understood when checking the P91 is for Vpro processors although the label of this equipment does not indicate that it is Vpro, so I recommend that you try the P91 first
              • lapfix
                • Mar 2020
                • 2756
                • my workshop
                #87
                Thank you 👍
                • PacoGT
                  • Sep 2022
                  • 105
                  • Guatemala
                  #88
                  I need help my friends, my BIOS is already fine, it boots quickly but the problem I have is that it does not activate the wifi, I press but it never activates, I do not know if it has to do with the wifi but I would like to see if you can help me with some idea, I leave the backup just in case
                  Hp probook 440 G4
                  DA0X81MB6E0 REV E
                  s/n 5CD7050Y9X
                  • AHSAN TARIQ
                    • Jan 2025
                    • 73
                    • Pakistan
                    #89
                    Hp probook 440 G4
                    DA0X81MB6E0 REV E
                    s/n 5CD7050Y9X
                    fix wifi issue
                    • PacoGT
                      • Sep 2022
                      • 105
                      • Guatemala
                      #90
                      Hp probook 440 G4
                      DA0X81MB6E0 REV E
                      s/n 5CD7050Y9X
                      It doesn't work, I'll tell you.
                      If I use the P85 BIOS, the computer turns on, but it takes more than 30 seconds to load the image. After that, the Wi-Fi and everything works. The Wi-Fi button also works, but when I turn it off, the computer doesn't turn off. It stays on a black screen with the LEDs on.
                      If I use the P91 BIOS, it turns on and off perfectly, and the image loads within 5 seconds of turning on.
                      But the Wi-Fi button doesn't work.
                      When I enter both BIOSes, I realized that the Wi-Fi enable option isn't available on the P91.
                      And is there a solution for this on the P85?
                      • flo19891448
                        • Jun 2025
                        Hi Guys,
                        i need help, i have a HP 440 G4 with a BIOS password on it.... i already test a Youtube video with a hex editor and uefi tools... but i dont know how to delete this bios password.... :-( the laptop works fine the only problem is that bios pw on it....
                        i hope one of you can delete this password now...
                        Details:
                        HP Probook 440 G4
                        Mainboard Model: DA0X81MB6E0 REV. E
                        SN:5CD6523QCT
                        ProdID: Y8B49EA#ABD
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12278
                          #92
                          Originally posted by flo19891448
                          Hi Guys,
                          Details:
                          HP Probook 440 G4
                          SN:5CD6523QCT
                          ProdID: Y8B49EA#ABD
                          Use RC unlocker
                          • markobi
                            HP Probook x360 11 G6 EE working bios is needed
                            by markobi
                            Hello everyone. I have this probook x360 11 G6 ALOE20 6050A3113201-MB-A01(A1). It has computrace and I need a working bios to get it working back to normal. I can really lay my hand on any bios file yet. My original bios file is also attached. Thanks in advance....
                            09-02-2023, 02:38 AM
                          • zPwN!
                            ENOVA NE14I310 XU133t rev 1.3 working BIOS
                            by zPwN!
                            Corrupted BIOS (no WIFI, graphics drivers crashing, USB port reset request failed, etc)
                            Working BIOS (taken from 15.0.41.2158_CON_LP_B_PRD_EXTR_AB7F54AC but I fixed some FLEX I/O for sata ssd and GPIO VCCIO config for this model)
                            System SKU NE14I310
                            BIOS Version APD-BI-14-XU133TR130-TA60F-143-E ?
                            Motherboard XU133T rev 1.3
                            Serial Number IPNBI3X240SM2A01095
                            Processor 11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz 3.00 GHz
                            RAM 8.00 GB
                            NOTE: I'm new repairing and not sure if this is everything that needed to be configured, but the BIOS...
                            01-03-2025, 01:03 AM
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • joven016
                            Lenovo Ideapad S145 need working bios HELP!!
                            by joven016
                            Problem is blinking power led only
                            i don't know exactly if it's s145-15igm or s145-14igm
                            have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                            Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                            Already tested some of posted bios here
                            S145-14igm - success but invalid serial and not booting on OS
                            S145-15igm - success with serial and some other info in bios but still not booting on OS
                            already tried installing new windows but always booting on bios setup
                            windows installer flash drive detected on...
                            08-21-2025, 10:55 PM
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
