HP Probook 440 G4 Working BIOS
  • subroto
    • Oct 2015
    • 230
    • Bangladesh
    DA0X81MB6E0 REV. E
    Working BIOS.
    Enjoy......
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP Probook 440 G4 Working BIOS
    Thanks bro
    • String2016
      • Nov 2015
      • 2238
      • philippines
      thanks for sharing
      • Pascal Komlassan
        • Jan 2017
        • 809
        • TOGO
        Nice job thanks
        • sourcebf
          • Jul 2016
          • 433
          • N/A
          thanks a lot
          • fyaagoub
            • 269
            • maroc
            thanks for sharing
            • nimmay
              • Dec 2015
              • 82
              • Pakistan
              thx subroto & the all badcaps members for the bios upload,
              bro i update bios & bios is working fine
              1 issue is that display is delay approx 20 sec minimum
              kindly give me solution for this error.
              i have previous 440 G4 with bios password ?
              thanks overall and waiting for the solution.
                • 21880
                The delay is because the ME (management engine) area of the bios is "dirty" .The ME firmware needs replacing in your bios, here`s the guide that everyone uses to clean (replace ME firmware) in the bios:
                https://winraid.level1techs.com/t/gu...lization/31277
                Its always best to post your original bios backup when asking for help,if you want a password removing or the ME area cleaning, if you can`t do it yourself .
                EDIT: Have you shared anything yet with this community .
                • nimmay
                  • Dec 2015
                  • 82
                  • Pakistan
                  SMDFlea ...
                  thanks for the help bro really appriciated.
                  bro i am uploading old bios which has password on bios ,
                  kindly clean it if you can...
                  waiting bro
                  • imranromi
                    • Jan 2015
                    • 1290
                    • Pakistan
                    Hello @SMDFlea same problem for me this bios file Hp 440 g4 i try all clean me work but when show display logo restart and restart in bios setup work 100% clean me problem or more other guys have checking fast display plz share thanks
                    Mistake rename file.File is 440 g4
                      • 21880
                      Your bios has corporate ME firmware,it should have had consumer FW. Try this bios
                      • imranromi
                        • Jan 2015
                        • 1290
                        • Pakistan
                        Thank you Friend you file work for me but 1 more problem new bios.Old late display file detect Nvidia Graphic card in Device manager this new file not detect Nvidia card when i check again old bios also show nvidia possible detect if use other clean me file..
                          • 21880
                          Ok, try this bios .
                          • imranromi
                            • Jan 2015
                            • 1290
                            • Pakistan
                            Ok, try this bios .
                            No work this file also late display 30sec after display
                              • 21880
                              what motherboard revision do you have X81-MB-D, rev E ?
                              • biospwd
                                Banned
                                • Oct 2019
                                • 51
                                • Ireland
                                Check this, should works.
                                • imranromi
                                  • Jan 2015
                                  • 1290
                                  • Pakistan
                                  Rev:E
                                    • 21880
                                    Try again with FITC.The ME firmware isn`t clean.
                                    "Warning: The ME FW image loaded has been pulled from a previously booted system. Some FW settings will not be allowed to be changed."
                                      • 21880
                                      Rev:E
                                      The rev E is UMA i think ? https://www.ebay.com/itm/905796-001-...id=24033761851
                                      • imranromi
                                        • Jan 2015
                                        • 1290
                                        • Pakistan
                                        Sorry i will check again what is correct Rev or Rev:E
                                        • markobi
                                          HP Probook x360 11 G6 EE working bios is needed
                                          by markobi
                                          Hello everyone. I have this probook x360 11 G6 ALOE20 6050A3113201-MB-A01(A1). It has computrace and I need a working bios to get it working back to normal. I can really lay my hand on any bios file yet. My original bios file is also attached. Thanks in advance....
                                          09-02-2023, 02:38 AM
                                        • zPwN!
                                          ENOVA NE14I310 XU133t rev 1.3 working BIOS
                                          by zPwN!
                                          Corrupted BIOS (no WIFI, graphics drivers crashing, USB port reset request failed, etc)
                                          Working BIOS (taken from 15.0.41.2158_CON_LP_B_PRD_EXTR_AB7F54AC but I fixed some FLEX I/O for sata ssd and GPIO VCCIO config for this model)
                                          System SKU NE14I310
                                          BIOS Version APD-BI-14-XU133TR130-TA60F-143-E ?
                                          Motherboard XU133T rev 1.3
                                          Serial Number IPNBI3X240SM2A01095
                                          Processor 11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz 3.00 GHz
                                          RAM 8.00 GB
                                          NOTE: I'm new repairing and not sure if this is everything that needed to be configured, but the BIOS...
                                          01-03-2025, 01:03 AM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • joven016
                                          Lenovo Ideapad S145 need working bios HELP!!
                                          by joven016
                                          Problem is blinking power led only
                                          i don't know exactly if it's s145-15igm or s145-14igm
                                          have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                          Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                          Already tested some of posted bios here
                                          S145-14igm - success but invalid serial and not booting on OS
                                          S145-15igm - success with serial and some other info in bios but still not booting on OS
                                          already tried installing new windows but always booting on bios setup
                                          windows installer flash drive detected on...
                                          08-21-2025, 10:55 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
