dell e6420 krug 14 UMA BIOS BIN NEEDED
  • akande
    • Dec 2017
    • 278
    • Nigeria
  • RAR1991
    • Apr 2017
    • 25
    • Algérie
    Re: dell e6420 krug 14 UMA BIOS BIN NEEDED
    is that a 6420 or 5420 please put the service TAG and the original dump if possible
    • RAR1991
      • Apr 2017
      • 25
      • Algérie
      anyway try this one, hope it will help you
      • akande
        • Dec 2017
        • 278
        • Nigeria
        Thank for reply, pls can I locate d bios chip on the board
        • akande
          • Dec 2017
          • 278
          • Nigeria
          Thanks it works fine
          • hussaka
            • Jan 2015
            • 154
            • italy
            thank you
            • zenius
              by zenius
              12-08-2024, 06:13 AM
            • mikeybass
              by mikeybass
              04-23-2025, 04:30 PM
            • capoplays
              Help with BIOS update on Dell G15 5515 after chip replacement
              by capoplays
              Hey everyone,
              I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
              The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
              When I check the BIOS using the F12 menu Flash...
              10-24-2025, 06:53 AM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
            • 417731
              BIOS needed for Dell Vostro 3405
              by 417731
              Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
              Model: Dell Vostro 3405
              Tag:F0B1YF3
              CPU:Ryzen 3500U
              Thanks in advance
              07-06-2025, 06:48 PM
