HP Omen 15-ax201ns bios dump
  • stingerchamp
    replied
    Re: HP Omen 15-ax201ns bios dump
    Originally posted by peste
    bios extracted from the HP site update, the laptop has six versions of your bios has 08217
    DMI 222000-2220FF
    KEYWIN 223000-22303F
    Thank you Sir
    Finaly someone replied
    Please tell me how to put this DMI info in bios file and yes bios has bid 08217
    and step by step process thank you.
    Furthermore Sir i forgot to mention getting 5.3 capslock error as i power on laptop.
  • peste
    replied
    Originally posted by stingerchamp
    Anyone help ?///////////////
    anyone????????????
    DMI 222000-2220FF
  • stingerchamp
    replied
    Anyone help ?
    flashing a bios chip failed it means bios chip is toasted? or need to get new chip from the market and flash it with working bios file
    Please help me so i go ahead and fix my laptop HP OMEN 15- AX236TX. if you want to check my bios file which i retreived from the chip please check above post.
    Waiting for a reply Bros
  • stingerchamp
    replied
    Originally posted by SMDFlea
    If it hasn`t worked from USB recovery then your only option is to use a programmer. Make a bios backup first,you can post it here if you want or go ahead and program the BID08217 .It has to be the right one,its the only bios for KABYLAKE H .Note that by programming a virgin bios you will lose all DMI info.That means the serial number and other info. There are some HP DMI tools posted here,and some videos too to help.
    Hi, I did as you said, i created backup of bios flash using ch341a programmer plus soci8 clip adapter from my bios chip , posting here my retrieved dump file from chip. I need help , please check this origional bios dump file which has 08217 bid you were right .
    I have already flashed bios with 08217( confirmed bin ) on my chip but still getting no display and capslock blink 5 long 3 short
    thanks in advance.
  • stingerchamp
    replied
    Thanks for your help. I will try to use these files to flash on bios chip using flash programmer. it will be last hope for my laptop mobo.
    I have done everything to save it but failed now only hope is flashing bios with fresh bin file .
    Yes i am trying to recover a bios file from USB or from this forum so i go ahead for flash programmer process.
    Hi guys ,
    Need HeLPPPPPPPPPPPPPP
    I have flashed my bios chip Gigadevice GD25B64CS1G using SPi flash programmer , bios file 80217F48, i have read old file using hex editor, bid is 08217 confirmed from old bios file. Now Hp omen 15 Ax236tx laptop fan running but still getting capslock 5 long blink and 3 short blinks. please help what to do next to fix this. any idea thanks
    replied
  • stingerchamp
    replied
  • stingerchamp
    replied
    trying to recover the bios . my system is dead and i went for a repair but that guy had no idea so i came back and trying my best to recover my laptop to play games. i ahve bought flash re programmer but not sure of which bios bin
    replied
    quick update 0209.bin missed my mistake.
    should i reupload??
    No, ive removed your attachment. Why post the virgin bios thats already posted here ? .Have you made a bios backup using an SPI bios programmer ? .Are you trying to recover the bios from USB ?
  • stingerchamp
    replied
    THANKS FOR HELP
    INFO: IN USB FLASH DRIVE i have two folders Hawelet-pack and one HP folder.
    subfolders are 3 current , previous (empty), devfw(empty).
    i have attached current folder bin files from HP folder.
    should i reupload??
  • stingerchamp
    replied
    THANKS FOR HELP
    replied
    Your cpu is a 7700HQ (H) so try the BID08217 KABYLAKE H.If you want to check the BID in your bios backup first ,open it with a hex editor and search for the word BID ,or post your bios backup here .
  • stingerchamp
    replied
    Yes.
    The Omen 15-ax***** has BID: 0820D, 08209 ,08217 .https://www.badcaps.net/forum/showthread.php?t=72828
    Check your BID number in your bios backup and CPU ID .
    BID08209 SKYLAKE U
    BID0820D SKYLAKE H
    BID0825F SKYLAKE H
    BID08294 SKYLAKE H
    BID08213 KABYLAKE U
    BID08217 KABYLAKE H
    hi , can i use 0820D or 08209
    i have intel corei7 7700HQ microprocessor kaby lake and intel HM175 chipset skylake
    Please Help which one is for my laptop
    Bios recovery flash has 6 files with 0820D.bin till 08217.bin
    replied
    Hi, my motherboard is dag35dmbad0 rev: d too can i use these bin files for HP omen 15-ax236tx ?. i do not have prev bios file. my laptop stop booting when i updates bios to F55 latest version.
    thanks for help.
    I am receiving 5.3 capslock blink error(5 long led blink ,3 short blinks)
    Yes.
    The Omen 15-ax***** has BID: 0820D, 08209 ,08217.https://www.badcaps.net/forum/showthread.php?t=72828
    BID08209 SKYLAKE U
    BID0820D SKYLAKE H
    BID0825F SKYLAKE H
    BID08294 SKYLAKE H
    BID08213 KABYLAKE U
    BID08217 KABYLAKE H
  • stingerchamp
    replied
    thanks for help.
  • JanoSilva94
    replied
    This List BIOS Working in Omen 15-AX250WN? the model board is dag35dmbad0 rev: d too
  • aashish chauhan
    replied
    Originally posted by ala_borbe
    here is bios for every version of HP Omen 15-ax201ns
    check you BID or try until you match bios
    those are virgin bios, not dumps from boards, so me is clean
    BID-08217 WORKING
  • hamid_seta
    replied
    Originally posted by DeniS182
    I need bios dump for this mobo: dag35dmbad0 rev: d
    I attached backuped bios file.
    Thanks.
    Hi Mate
    I know it is too late but for Others update, I checked the Bios file and its ok.
    Tnx
  • ala_borbe
    replied
  • DeniS182
    replied
    Thanks.
    and 7J is RT8816AGQW. No voltages on IC's.. only 19V is on mosfet near DC IN connector. I need schematic..Does anyone have it?
    MOD EDIT: Schematic posts moved to a new thread - https://www.badcaps.net/forum/showthread.php?t=85695
    Last edited by SMDFlea; 06-29-2020, 10:48 AM. Reason: Schematics moved to a new thread in "Schematic Requests ONLY!" sub-forum
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • Dani Rahal
    hp omen 17-cb0247ng bios
    by Dani Rahal
    Hi can some one help me plz
    i have hp omen 17-cb0247ng (la h492p) it have bios problems and i flashed bios from usb the new one v53 and its boosting to bios but did not start to windows (blue screen of death) i tryed evry thig and not working
    i flashed bios with programer ( CH341A )and it will not boost to bios just fan working no disply now i flash the orginal bios back its working but no booting to windows same problem
    the bios from hp after extract have 4 bios file same size i tryed 4 of them not working
    i have the orginal bios if some one can see what the problem or...
    05-30-2025, 09:11 AM
  • DavidJocic
    Omen 15-dc1056nf (Need Dump Bios or something ) Thanks :(
    by DavidJocic
    Hello everyone firstly i'm thankfully if someone can help me if not i'm very stupid i have use ch341-a to flash my bios when i was deleted chip and loose my original backup, then the problem comes my laptop won't start only red light blinking without boot and without screen and fans but electricity is there in light close to charger. Chip was not damaged cause via application works when i want to update. Probleme is next i even tryed to download official bios from hp and put there informations of my serials numbers which is : 5CD938GPG1 (with HxD ). My model is with chip name winbond 25Q128JVSQ...
    04-28-2025, 12:54 PM
  • DynaxSC
    by DynaxSC
    11-17-2023, 10:56 AM
  • grimacelord
    Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
    by grimacelord
    This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
    Motherboard model number: DA0PAMB46A1 REV: A
    Secondary motherboard model number: 0PAB
    SKU: 685K4UA
    Serial number is: 5CD3223BJP
    Recently reflashed this laptop with latest BIOS and once...
    05-07-2024, 08:06 AM
