Asus K52JR rev 2.2 / A52JE bios
  • Lukkas
    • Apr 2012
    • 7
    • Slovakia
    I have this laptop, I try turn on but only black screen, fan is OK, cpu is hot.
    I read the old bios and here is. Do you can check it? I reflashed it lot of times from bios dump from internet but nothing work.
    Thanks for help.
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Asus K52JR rev 2.2 / A52JE
    please mention more symptoms of the laptop. Does Capslock work? Does it display anything on external monitor?
    • cacla
      • Apr 2015
      • 444
      This is 100% working dump
      • Lukkas
        • Apr 2012
        • 7
        • Slovakia
        It's working now.
        I go test with others RAMs and other staff.
        Thank you so much!
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • pirati
          by pirati
          10-27-2025, 04:20 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
