Asus K52JR rev 2.2 / A52JE bios
  • Lukkas
    • Apr 2012
    • 7
    • Slovakia
    I have this laptop, I try turn on but only black screen, fan is OK, cpu is hot.
    I read the old bios and here is. Do you can check it? I reflashed it lot of times from bios dump from internet but nothing work.
    Thanks for help.
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Asus K52JR rev 2.2 / A52JE
    please mention more symptoms of the laptop. Does Capslock work? Does it display anything on external monitor?
    • cacla
      • Apr 2015
      • 442
      This is 100% working dump
      • Lukkas
        • Apr 2012
        • 7
        • Slovakia
        It's working now.
        I go test with others RAMs and other staff.
        Thank you so much!
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • kodox
          Asus ExpertBook B1400CB Bios Dump Needed
          by kodox
          need original bios dump, original bios has flashed by other technician before me.
          attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
          unit info:
          Model: Asus ExpertBook B1400CBA-0711A1235U
          S/N: R6NXNZ006657238
          CN: 7F6F
          Mainboard Code: B1500CBA R2.1...
          Yesterday, 12:20 PM
