no video
no boot
no vcore
same problem
			LENOVO V110-15ISK Need Bios
V110-15ISK Laptop (Lenovo) - Type 80TL
help the laptop turn on and no video capslock key is turn on and fan speed
please repair the backup
lenovo v110-15lsk
model name 80tl
sn r90mc0d4Attached FilesLeave a comment:
tnxAttached FilesLeave a comment:
hiii
need help my divce turn on but no display and capslock key light on
fan is on but noooooo display
LV115SK MB 15277-1N 448.08B01.001N
V110-15ISK 80 TL
SN:R90R2FA6Leave a comment:
post S/N, full name and model, motherboard model, TYPE,etc.На Lenovo V110-15ISK невозможно загрузиться с карты MicroSD (с помощью адаптера MicroSD-to-SD). Кроме того, BIOS вообще не определяет карту MicroSD.
Отключена ли эта функция в BIOS? Если да, может ли кто-нибудь изменить его, чтобы включить эту функцию?
On Lenovo V110-15ISK it is not possible to boot from MicroSD card (using MicroSD-to-SD adapter). Also, BIOS does not detect MicroSD card at all. Is this feature disabled in BIOS? If so, can anyone change it to enable this feature?
in English please..
post the contents of the bios chip even if it is corrupted..
read the forum rules..
https://www.badcaps.net/forum/troubl...ore-postingLeave a comment:
On the Lenovo V110-15ISK, it is impossible to boot from a MicroSD card (using a MicroSD-to-SD adapter). Additionally, the BIOS does not detect the MicroSD card at all.
Is this disabled in the BIOS? If yes, can someone modify it to enable this feature?Leave a comment:
tryAttached FilesLeave a comment:
A reminder. Post the laptop serial number.... https://www.badcaps.net/forum/troubl...before-postingLeave a comment:
It's working but late display. Please help me with Clean ME
Some following bios not work for me.
Thanks in advanceLeave a comment:
I tried the various dumps and tried to replace the spi with a new one but they don't work. The notebook as soon as it powers on, the led caps are on, the fan starts to spin for 30sec then stops to restart faster.Leave a comment:
Hi Guys, I need Bios for Lenovo V110-15ISK
Main LV155K 15277-1N
448.08B01.001N
SPI Gigadevice 25Q64B
upload original dump
TanksAttached FilesLeave a comment:
Can you repost the working bios. The link is no more accessible. Thanks.Re: LENOVO V110-15ISK Need Bios
https://www.badcaps.net/forum/attach...3&d=1572036143
this bios works for me too
thanks a lot!!Leave a comment:
			by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
 - I have a CH341A programmer and have successfully created two full backups of my BIOS.
 - I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
 - I concluded that the
							Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
			by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
			by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
			by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
			by mkdjDear all,
I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
Here the steps I have taken to fix the laptop:
- downloaded latest BIOS from Lenovo Website... - Loading...
