bios dump elitebook 840 g3
  • jhonvizco
    • Jul 2008
    • 5
    #161
    Re: HP 840 G3 bios needed
    Originally posted by imranromi
    Try this
    Thanks will try it .
    • jhonvizco
      • Jul 2008
      • 5
      #162
      Try this
      Kudos to you my friend it worked like a charm
      • aldopc
        • Jul 2017
        • 465
        • Chilito
        #163
        Try this
        Hola Imranromi please i need your help with this bios hp 840 g3 main p / n 6050A2822301-MB-A01 thank you very much.
        • imranromi
          • Jan 2015
          • 1288
          • Pakistan
          #164
          Try this.
          • aldopc
            • Jul 2017
            • 465
            • Chilito
            #165
            Try this.
            Thank you very much Imranromi, I programmed the bios with the bin that he gave me but I do not have an image, it is black while the fan starts walking at full speed, do you have any idea? very thankful
            • imranromi
              • Jan 2015
              • 1288
              • Pakistan
              #166
              Try this.
              • aldopc
                • Jul 2017
                • 465
                • Chilito
                #167
                Try this.
                Hello Inramroni how are you, I have loaded the bios that you sent me for the second time but still in the same state black image and fan at full speed after block mayus blink 5 times, I have also tried to load the original bios that has password but exactly the same happens ... the truth is I'm not interested in the mainboard just for me it's important to learn you have some idea I appreciate your patience.
                • imranromi
                  • Jan 2015
                  • 1288
                  • Pakistan
                  #168
                  Means original bios black image?Which programmer you use?
                  • aldopc
                    • Jul 2017
                    • 465
                    • Chilito
                    #169
                    means original bios black image?which programmer you use?
                    ezp2010
                    • imranromi
                      • Jan 2015
                      • 1288
                      • Pakistan
                      #170
                      Now original black image?
                      • aldopc
                        • Jul 2017
                        • 465
                        • Chilito
                        #171
                        Yes not image with original bin
                        • imranromi
                          • Jan 2015
                          • 1288
                          • Pakistan
                          #172
                          This thread have many bios use maybe someone give display lock or unlock use all
                          • aldopc
                            • Jul 2017
                            • 465
                            • Chilito
                            #173
                            Ok, what do you think could be the problem?
                            • imranromi
                              • Jan 2015
                              • 1288
                              • Pakistan
                              #174
                              Maybe your programmer bad or corrupt read i think this board bios chip WSOP8 right?
                              • aldopc
                                • Jul 2017
                                • 465
                                • Chilito
                                #175
                                your bios-pass cleared. Enjoy.
                                PS: Why dont you do it yourself?? Its so easy.
                                Could you tell me how to remove the password from the file? thank you
                                • aldopc
                                  • Jul 2017
                                  • 465
                                  • Chilito
                                  #176
                                  Hello the bios chip is wson8 type with the pins hidden as the image .... I will get another programmer to perform other tests thanks.
                                  • imranromi
                                    • Jan 2015
                                    • 1288
                                    • Pakistan
                                    #177
                                    Yes right
                                    • sapkad
                                      • Feb 2019
                                      • 6
                                      • Lietuva
                                      #178
                                      Hi Imranromi please i need your help with this bios hp 840 g3 main p / n 604B0178501-MB-A01 thank you very much.
                                      • imranromi
                                        • Jan 2015
                                        • 1288
                                        • Pakistan
                                        #179
                                        Try this
                                        • sapkad
                                          • Feb 2019
                                          • 6
                                          • Lietuva
                                          #180
                                          black screen, fan full speed and hdd lamp lights yellow
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • mediadoctor
                                            Need bios dump HP EliteBook G845 G8 with AMD and Touchscreen support
                                            by mediadoctor
                                            Can you help me upload Bios dump from HP EliteBook 845 G8 with AMD CPU and Touchscreen please 🤝
                                            07-20-2025, 09:38 AM
                                          • Guest
                                            Elitebook 850 G5 BIOS bricked
                                            by Guest
                                            I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                            I assume the BIOS update failed, so I searched for the BIOS chip.
                                            I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                            However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                            Can the corrupted...
                                            03-24-2025, 01:21 AM
                                          • MDSI
                                            HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                            by MDSI
                                            I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                            Details:
                                            Model : HP OMEN 17-an012nf
                                            Motherboard Part Number : DAG3BAMBAF0 REV : F
                                            Serial Number (S/N) : 5CD7280D51
                                            BIOS chip : Winbond W25Q64VSIQ
                                            Programmer : EZP2023+
                                            Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                            I already...
                                            07-28-2025, 07:11 AM
