bios dump elitebook 840 g3
  • classicandy
    • Apr 2018
    • 308
    • Nigeria
    #541
    Re: bios dump elitebook 840 g3
    Hi everyone.
    Can I replace WSON8 [MXIC MX25L12873FZNI] with SOP-8 [Winbond 25Q128FVSG] chip on 840 g3?
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      #542
      Originally posted by classicandy
      Hi everyone.
      Flash ROM ID's must be in the VSCC table within the BIOS (Descriptor region).
      Become a Badcaps supporter
      Thanks to all supporters.​
      • classicandy
        • Apr 2018
        • 308
        • Nigeria
        #543
        Sorry I don't understand. So basically, you mean I can't?
        I use CH341A programmer and I've had issues writing on WSON8 chips
        • classicandy
          • Apr 2018
          • 308
          • Nigeria
          #544
          Originally posted by peste
          the bios is empty..remove the bios chip from the motherboard before writing or reading..or glue wires between chip and proframator, do not use the clip..if errors..use these programs ... and post again ..
          https://www.badcaps.net/forum/showpo...04&postcount=7
          https://www.badcaps.net/forum/showpo...6&postcount=10
          https://www.youtube.com/watch?v=DWWigscuQDY
          But I want to try this out. Hoping to be successful.
          • classicandy
            • Apr 2018
            • 308
            • Nigeria
            #545
            Write and verify successful..... Laptop still not displaying. Flashing white and orange led continuously.
            Original problem of this laptop was BIOS Admin password. Original BIOS was wiped by previous repair techs before it got to me.
            I flashed with the attached file gotten from this thread in Post #524.
            Please I need EC file. Seems the current one must have been tampered with also.
            • Temp_user1
              • Oct 2021
              • 7
              You are most likely getting white and orange lights because the bios chip is not properly soldered on. Try pushing down on it when applying hot air.
              • classicandy
                • Apr 2018
                • 308
                • Nigeria
                #547
                It turned out that the other BIOS chip was the wrong one put by the former repair tech. After replacing it with the correct one and flashing a backup dump from a similar working laptop, the Laptop now powers On but no display and the Capslock blinks 5 times.
                I did trace the legs of the chips with continuity and they are reading ok
                • razycool0
                  • Oct 2021
                  • 10
                  • maroc
                  #548
                  Hi, please help me to unlock bios password for elitebook 840 g3
                  6050A2728501-MB-A01
                  thanks
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #549
                    6050A2728501-MB-A01
                    thanks
                    • razycool0
                      • Oct 2021
                      • 10
                      • maroc
                      #550
                      I'll try this one and tell you the result.
                      thanks again
                      • razycool0
                        • Oct 2021
                        • 10
                        • maroc
                        #551
                        thanks alot, it works ,
                        can you tell me wich tools did you use please,
                        because i did try with HP unlocker but couldn't unlock it.
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          #552
                          You're welcome.
                          I didn't used a tool, just edited the file. Your attempt with the HPUnlocker failed because in your case there was a user (not admin) password set.
                          • razycool0
                            • Oct 2021
                            • 10
                            • maroc
                            #553
                            ok, i see, this pc belong to my neighber, he had instal hp assistence support and when reboot the pc, it ask for password even if he didn't put it, thanks again
                            • dragon92
                              • Apr 2015
                              • Polska
                              #554
                              Hi, please help me to unlock bios password for Elitebook 840 G3
                              6050A2728501-MB-A01
                              • peste
                                • 12593
                                • ROMANIA
                                #555
                                6050A2728501-MB-A01
                                the posted bios is longer .. be careful how you write this one..try this ..
                                • soimu
                                  • Dec 2020
                                  • Молдова
                                  #556
                                  Hi. hp 840 g3 Motherboard number 6050a2892401-mb-a01 . I tried to reset the BIOS password and tried different dumps . now the screen is black and the fan is running at maximum . the original bios also does not turn on . help to solve the problem
                                  • peste
                                    • 12593
                                    • ROMANIA
                                    #557
                                    try..
                                    • soimu
                                      • Dec 2020
                                      • Молдова
                                      #558
                                      try..
                                      does not work ,
                                      • soimu
                                        • Dec 2020
                                        • Молдова
                                        #559
                                        solved , thank you all . the problem is programmer tnm5000 . with rt809h things are good
                                        • sdr1
                                          • Nov 2019
                                          • 6
                                          #560
                                          Hi!
                                          Need help for unlock elitebook 840 G3 bios pass .
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • Guest
                                            Elitebook 850 G5 BIOS bricked
                                            by Guest
                                            I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                            I assume the BIOS update failed, so I searched for the BIOS chip.
                                            I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                            However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                            Can the corrupted...
                                            03-24-2025, 01:21 AM
                                          • grimacelord
                                            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                            by grimacelord
                                            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                            Motherboard model number: DA0PAMB46A1 REV: A
                                            Secondary motherboard model number: 0PAB
                                            SKU: 685K4UA
                                            Serial number is: 5CD3223BJP
                                            Recently reflashed this laptop with latest BIOS and once...
                                            05-07-2024, 08:06 AM
                                          • DynaxSC
                                            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                            by DynaxSC
                                            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                            11-06-2022, 05:22 PM
