bios dump elitebook 840 g3
  • peste
    • 12562
    • ROMANIA
    #381
    Re: bios dump elitebook 840 g3
    Originally posted by thandazile85@gmail.com
    hi guys i need bios bin for 840 g3
    post the original laptop bios
    • vpiru1
      • Oct 2020
      • Portugal
      #382
      Re: HP ELITEBOOK 840 G3 (6050A2892401-MB-A01) remove Bios password
      looks like hpunlocker tool rar file is corrupted, at least i can't unrar it.
      is there any other place to download it besides (https://www.badcaps.net/forum/showpo...43&postcount=1 )
      • peste
        • 12562
        • ROMANIA
        #383
        update winrar or use 7zip ..
        • vpiru1
          • Oct 2020
          • Portugal
          #384
          thx, 7zip worked fine.
          • vpiru1
            • Oct 2020
            • Portugal
            #385
            and btw, does the tool clear the power on password? that's my problem.
            • 5chematic
              • Jun 2019
              • 77
              HP EliteBook 850 G3 corrupted extracted image
              I was dumping an image when my programmer was flipped over just a tiny bit. as the result of that micro accident, I got a corrupted image. I extracted the image 2 times and then compared both copies and they are different.
              I've tried to make one image from both, but did not worked. then I grabbed another image from another hp which is the same model and then tried to edit the serial but cannot get a working image.
              Could anyone help me?
              Thanks in advance
              • Bonzas
                • 469
                • Indonesia
                #387
                Re: HP EliteBook 850 G3 corrupted extracted image
                try this
                • 5chematic
                  • Jun 2019
                  • 77
                  Thank you so much Martha, let me try and let you know. thank you again.
                  • 5chematic
                    • Jun 2019
                    • 77
                    Martha, I get a loop of three long beeps and two short beeps The same as before, Please help.
                    • Claudiomfa
                      • Nov 2015
                      • 455
                      • Portugal
                      #390
                      3 long beeps and 2 short beeps means:
                      Indicates potential memory failure.
                      Reseat memory.
                      Correct memory configuration (correct DIMM placement and size/type matching).
                      Test with known good memory.
                      Replace affected component.
                      • zerocool87
                        • Oct 2020
                        • deutschland
                        #391
                        Re:elitebook 840 g3 lock
                        hello please help me to unlock my bios attached my bios dump
                        • 5chematic
                          • Jun 2019
                          • 77
                          Reseat memory.
                          Hello Claudio,
                          Thank you for your comment.
                          Let me explain what happened...
                          I was dumping the image of the bios chip from the laptop.
                          Then out of nowhere my programmer flipped over just a bit, and very slowly while I was extracting the image from the chip. I never thought the bios image could get corrupted just by that tiny flip, but it happened.
                          Then after I encounter the issue I removed the chip again and made another copy, I mean, I extracted the chip again. and I noticed that the image was not the same. I compared them and both copies were not the same. there is a tiny difference in both images.
                          I was removing the bios password from the image as usual. now all I want is to get a working copy of the bios.
                            • 20617
                            Re: elitebook 840 g3 lock
                            Use the HP unlocker tool - https://www.badcaps.net/forum/showthread.php?t=79956
                              • 20617
                              The bios at post #2 has initialised ME firmware,which means that it would need cleaning , or just search the forum for an 850 G3 bios with clean ME firmware.
                                • 20617
                                Thanks in advance
                                ok ,try this bios .
                                • 5chematic
                                  • Jun 2019
                                  • 77
                                  Hello SMDFlea, Thank you so much for this achievement. the image worked fine. after I turned the hp on, the bios was updated automatically. does this means that I should not worry about any serial number, and so on? Thank you again SMFlea.
                                  I also wanted to add that Claudio was right. after I installed the new bios image, the beep was still there. then remembered what Claudio mentioned on post #5. so what I did is move one stick of ram to the other slot and that took care the beeping sound. Thank You Claudio.
                                  • newjan
                                    • Mar 2016
                                    • 67
                                    • Egypt
                                    #397
                                    i need dumo work with 840 g3 coz i lost my backup
                                    • peste
                                      • 12562
                                      • ROMANIA
                                      #398
                                      what motherboard model ?? give you more details about laptop ...
                                      • newjan
                                        • Mar 2016
                                        • 67
                                        • Egypt
                                        #399
                                        6050a2822301-mb-a01
                                        • peste
                                          • 12562
                                          • ROMANIA
                                          #400
                                          6050a2822301-mb-a01
                                          try..
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • Guest
                                            Elitebook 850 G5 BIOS bricked
                                            by Guest
                                            I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                            I assume the BIOS update failed, so I searched for the BIOS chip.
                                            I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                            However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                            Can the corrupted...
                                            03-24-2025, 01:21 AM
                                          • grimacelord
                                            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                            by grimacelord
                                            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                            Motherboard model number: DA0PAMB46A1 REV: A
                                            Secondary motherboard model number: 0PAB
                                            SKU: 685K4UA
                                            Serial number is: 5CD3223BJP
                                            Recently reflashed this laptop with latest BIOS and once...
                                            05-07-2024, 08:06 AM
                                          • DynaxSC
                                            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                            by DynaxSC
                                            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                            11-06-2022, 05:22 PM
