ASUS A553S Bios pass word
  • cacla
    • Apr 2015
    • 442
    Re: ASUS A553S Bios pass word
    By sn this is your dump
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      Dear Cacla, No it didnt worked. I'm surprised by the fact that when i copied the original file and saved it in my laptop-again write it with another 1.8v chip-it goes dead. I'm using RT809F programmer with 1.8v adapter to do this. So surprised why not working. I doubt perhaps all the dumps are ok-still puzzled why not working.
      I tested my programmer and 1.8v adapter by reading and writing Lenovo nm-a311 eeprom chip(also 1.8v)- It worked like a charm. So neither my programmer nor my 1.8v adapter is faulty.
      Can anybody advice why even a original bios when copied and flashed on another chip-not working??
      PS: All the chips i used are ok-tested them on NM-A311 mb.
      I'm Using EZP2010, Only chip Winbond 1.8V that have been passed verifying when flashing bios. Others chips give me error and problems else.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Thanks for all the responses. Will try andrevert back with the dumps of cacla and ala borbe. I tried merging asus official ver 205/204/202 with my dump but all didnt worked. Then i asked for help.
        I have used 1.8v chip of winbond/gigadevice-both didnt worked on asus. Altogether 4 bios chips tried and all 4 worked on nm-a311 mb. So once again i confirm that neither my programmer nor my chips are bad.
        I too seriously doubt that there is some kind of protection in the original chip which perhaps cant be read fully resulting in non working bios. If it is so-then i have come across such a thing first time in my carrier and is acause of concern for all of us.
        In the mean time i request ala borbe to do tinkering with nvram or whatever you deems fit to make my dump working.
        Fortunately, i didnt erase the orignal bios chip-else could have benn in trouble.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Unfortunately both the dumps didnt worked-one by cacla and other by alaborbe
          • caspian
            • Oct 2015
            • 1589
            • Laptop
            Before any more programming, the protection problem should be solved.
            • rioreno
              • Feb 2009
              • 540
              • Indonesia
              #26
              try this below..
              btw..have you try asus pwd recovery by date?
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                #27
                Originally posted by rioreno
                try this below..
                its showing 2012/01/01 as date. Any ideas??
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  #28
                  try this below..
                  Didnt worked. I'm wondering why original bios copied and flashed on another chip didnt work. As told earlier i made a copy of the password protected bios and flashed it on a new eeprom(both 1.8v chips)-still it goes dead. Does that means when i'm copying its missing some bytes or blocks?? Some kind of protection is at play??
                  • Herr25
                    • Jan 2015
                    • 3
                    • Russian Federation
                    #29
                    I think that it is because of different eeprom chips. On my mainboard is 25Q64FWSIQ, if you install 25Q64FWSIG, you would set Quad mode in eeprom cohfig before programming
                    • nirmal
                      • Sep 2015
                      • uae
                      #30
                      Originally posted by ala_borbe
                      Try putting older bios in it, or get dump from another laptop
                      Maybe if you do not have any other option i can play a bit with nvram to figure where password is stored
                      also try this
                      working fine for me
                      • bekerek
                        • May 2014
                        • 14
                        • Poland
                        #31
                        Hi, i'm lookin for KBC EC bios for X553SA rev2.0. Anyone? Thanks in advance.
                        • Anselme
                          • Jul 2016
                          • 21
                          • Ghana
                          #32
                          Hi all, I'll like to share this discovery with you all on x553sa pu8101 qfn ic, boardview says NBS_QFN_32P_4V_007 only which is rt8161b ic marked 2W=2M well after an hour of research, I came across RT8175AGQW with ic marked 3P=3H. And one little secret there is I used the generation of the processor to arrive at this ic matching which is SR2KN the clue there is (SR2) thanks, hope it helps someone some day.
                          ANSTECH refix 🇬🇭
                          • razor_amd
                            by razor_amd
                            12-15-2020, 07:07 PM
                          • grimacelord
                            by grimacelord
                            07-10-2025, 02:52 PM
                          • throwaway327
                            by throwaway327
                            Model No: RC72LA
                            Serial No: SBNVKD001014459
                            06-18-2025, 05:52 PM
                          • jbonavita
                            by jbonavita
                            Some issues
                            Things I tried
                            04-29-2025, 09:38 PM
                          • lrouw84
                            by lrouw84
                            Hi there,
                            01-28-2023, 01:31 PM
