ASUS A553S Bios pass word
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Model-ASUS A553S
    M/B CODE: X553SA REV 2.0
    Mine is password protected. I tried rebulding my bios with asus update file but m/b is completely dead after new bios flash. Its a 1.8v bios chip-so i have used 1.8v adapter to read and write bios. I'm not able to understand why the new bios didnt worked. can anybody here give me a working dump or rebuild mine .
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: ASUS A553S Bios pass word
    try this,
    Have you verified that the chip is well programmed ?
    • cacla
      • Apr 2015
      • 442
      Hi there sent me serial number and i will find you dump in asus system
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Originally posted by cacla
        hi there sent me serial number and i will find you dump in asus system
        fanocv95987144a
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Originally posted by jasko_jacker
          try this,
          Thanks jasko, I'll try and revert back with feedback. I used RT809F with 1.8v adapter to read and write bios chip-so i think there is no error in writing there.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            dear jasko, i flashed bios posted by you-but it beomes complete dead after flash. If i put original dump again, there is display.
            • cacla
              • Apr 2015
              • 442
              fanocv95987144a
              This is not the correct serial pls sent me photo form sticker. But i found one form them pls try this and if its ok sent msg
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Thanks Cacla, I'll try and post result
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  fanocv95987144a
                  FAN0CV95987144 This is 100% correct. You can check with my original dump. Just press CTRL-F and type X553SA . You will see the serial number.
                  • vhn1998
                    • Jun 2015
                    • 56
                    • Vietnam
                    try this. you can make as video guide
                    https://youtu.be/XN7KdytCLB4
                    • cacla
                      • Apr 2015
                      • 442
                      It works with my dump ?
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Thanks VHN for response. I know how to rebuild bios. I tried it but in this particular case-I'm puzzled.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Dear Cacla, No it didnt worked. I'm surprised by the fact that when i copied the original file and saved it in my laptop-again write it with another 1.8v chip-it goes dead. I'm using RT809F programmer with 1.8v adapter to do this. So surprised why not working. I doubt perhaps all the dumps are ok-still puzzled why not working.
                          I tested my programmer and 1.8v adapter by reading and writing Lenovo nm-a311 eeprom chip(also 1.8v)- It worked like a charm. So neither my programmer nor my 1.8v adapter is faulty.
                          Can anybody advice why even a original bios when copied and flashed on another chip-not working??
                          PS: All the chips i used are ok-tested them on NM-A311 mb.
                          • cacla
                            • Apr 2015
                            • 442
                            all my dumps are form asus sip server they use these dumps to repair boards. Psl sent me picture form the back side (the sticker) of notebook i will find your dump.
                            • ala_borbe
                              aka Donald
                              • 1625
                              • Malta
                              why so serious?
                              use this and enjoy
                              eeproms can be faulty too... i have some that can be read but not written
                              tested with may working programmers
                              sometimes some address are not writtable
                              so always verify when reading backups and writing new
                              Im Back... sort of...
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Originally posted by ala_borbe
                                why so serious?
                                use this and enjoy
                                Thanks Ala Borbe for responding but unfortunately its the same story-dead-no lights nothing. Again put up the original bios-display comes with password.
                                I took backup after flashing your dump and compared in hex editor- Your dump & my Backup after flashing your dump-No difference in file structure-100% same.
                                My chips cant be faulty as i tested all 3 chips on NM-A311 mb and got display.
                                So, i"m still wondering whats wrong-why system goes dead after flashing. No resistor or caps nearby has dislocated.
                                Seems like looking at the dead end.
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  Here is the image attached.
                                  • ala_borbe
                                    aka Donald
                                    • 1625
                                    • Malta
                                    Try putting older bios in it, or get dump from another laptop
                                    Maybe if you do not have any other option i can play a bit with nvram to figure where password is stored
                                    also try this
                                    • caspian
                                      • Oct 2015
                                      • 1591
                                      • Laptop
                                      are the two Bios chips exactly the same model?
                                      If so, this is really strange. maybe, this reveals some new fact that the original Bios chip is also protected somehow, so that it can not be replaced. this is just a guess and it is hopefully not true.
                                      • ala_borbe
                                        aka Donald
                                        • 1625
                                        • Malta
                                        some bios have list of supported chips in descriptor region
                                        other bios have some tricks that write some data after bios is flashed
                                        but in that case utis does some "tricks" with gpio pins that are modified after flash on first boot
                                        however that pins are not modified when you write flash with programmer
                                        and bios cannot do its magic hence canot boot propertly
                                        remember on some machines when you flash bios, mobo turns on, does something, shut off and then turns back on?
                                        similar trick
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • lrouw84
                                          by lrouw84
                                          Hi there,
                                          01-28-2023, 01:31 PM
