ASUS A553S Bios pass word
  • Anselme
    replied
    Re: ASUS A553S Bios pass word
    Hi all, I'll like to share this discovery with you all on x553sa pu8101 qfn ic, boardview says NBS_QFN_32P_4V_007 only which is rt8161b ic marked 2W=2M well after an hour of research, I came across RT8175AGQW with ic marked 3P=3H. And one little secret there is I used the generation of the processor to arrive at this ic matching which is SR2KN the clue there is (SR2) thanks, hope it helps someone some day.
    ANSTECH refix 🇬🇭
  • bekerek
    replied
    Hi, i'm lookin for KBC EC bios for X553SA rev2.0. Anyone? Thanks in advance.
  • nirmal
    replied
    Originally posted by ala_borbe
    Try putting older bios in it, or get dump from another laptop
    Maybe if you do not have any other option i can play a bit with nvram to figure where password is stored
    also try this
    working fine for me
  • Herr25
    replied
    I think that it is because of different eeprom chips. On my mainboard is 25Q64FWSIQ, if you install 25Q64FWSIG, you would set Quad mode in eeprom cohfig before programming
  • mcplslg123
    replied
    Originally posted by rioreno
    try this below..
    btw..have you try asus pwd recovery by date?
    Didnt worked. I'm wondering why original bios copied and flashed on another chip didnt work. As told earlier i made a copy of the password protected bios and flashed it on a new eeprom(both 1.8v chips)-still it goes dead. Does that means when i'm copying its missing some bytes or blocks?? Some kind of protection is at play??
  • mcplslg123
    replied
    try this below..
    its showing 2012/01/01 as date. Any ideas??
  • rioreno
    replied
    try this below..
  • caspian
    replied
    Before any more programming, the protection problem should be solved.
  • mcplslg123
    replied
    Unfortunately both the dumps didnt worked-one by cacla and other by alaborbe
  • mcplslg123
    replied
    Thanks for all the responses. Will try andrevert back with the dumps of cacla and ala borbe. I tried merging asus official ver 205/204/202 with my dump but all didnt worked. Then i asked for help.
    I have used 1.8v chip of winbond/gigadevice-both didnt worked on asus. Altogether 4 bios chips tried and all 4 worked on nm-a311 mb. So once again i confirm that neither my programmer nor my chips are bad.
    I too seriously doubt that there is some kind of protection in the original chip which perhaps cant be read fully resulting in non working bios. If it is so-then i have come across such a thing first time in my carrier and is acause of concern for all of us.
    In the mean time i request ala borbe to do tinkering with nvram or whatever you deems fit to make my dump working.
    Fortunately, i didnt erase the orignal bios chip-else could have benn in trouble.
  • meritosari
    replied
    Dear Cacla, No it didnt worked. I'm surprised by the fact that when i copied the original file and saved it in my laptop-again write it with another 1.8v chip-it goes dead. I'm using RT809F programmer with 1.8v adapter to do this. So surprised why not working. I doubt perhaps all the dumps are ok-still puzzled why not working.
    I tested my programmer and 1.8v adapter by reading and writing Lenovo nm-a311 eeprom chip(also 1.8v)- It worked like a charm. So neither my programmer nor my 1.8v adapter is faulty.
    Can anybody advice why even a original bios when copied and flashed on another chip-not working??
    PS: All the chips i used are ok-tested them on NM-A311 mb.
    I'm Using EZP2010, Only chip Winbond 1.8V that have been passed verifying when flashing bios. Others chips give me error and problems else.
  • cacla
    replied
    By sn this is your dump
  • ala_borbe
    replied
    some bios have list of supported chips in descriptor region
    other bios have some tricks that write some data after bios is flashed
    but in that case utis does some "tricks" with gpio pins that are modified after flash on first boot
    however that pins are not modified when you write flash with programmer
    and bios cannot do its magic hence canot boot propertly
    remember on some machines when you flash bios, mobo turns on, does something, shut off and then turns back on?
    similar trick
  • caspian
    replied
    are the two Bios chips exactly the same model?
    If so, this is really strange. maybe, this reveals some new fact that the original Bios chip is also protected somehow, so that it can not be replaced. this is just a guess and it is hopefully not true.
  • ala_borbe
    replied
    also try this
  • mcplslg123
    replied
    Originally posted by cacla
    all my dumps are form asus sip server they use these dumps to repair boards. Psl sent me picture form the back side (the sticker) of notebook i will find your dump.
    Here is the image attached.
  • mcplslg123
    replied
    why so serious?
    use this and enjoy
    eeproms can be faulty too... i have some that can be read but not written
    tested with may working programmers
    sometimes some address are not writtable
    so always verify when reading backups and writing new
    Thanks Ala Borbe for responding but unfortunately its the same story-dead-no lights nothing. Again put up the original bios-display comes with password.
    I took backup after flashing your dump and compared in hex editor- Your dump & my Backup after flashing your dump-No difference in file structure-100% same.
    My chips cant be faulty as i tested all 3 chips on NM-A311 mb and got display.
    So, i"m still wondering whats wrong-why system goes dead after flashing. No resistor or caps nearby has dislocated.
    Seems like looking at the dead end.
  • ala_borbe
    replied
    why so serious?
    use this and enjoy
  • cacla
    replied
  • mcplslg123
    replied
    It works with my dump ?
  • razor_amd
    by razor_amd
    12-15-2020, 07:07 PM
  • pirati
    by pirati
    10-27-2025, 04:20 PM
  • grimacelord
    by grimacelord
    07-10-2025, 02:52 PM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
  • throwaway327
    by throwaway327
    Model No: RC72LA
    Serial No: SBNVKD001014459
    06-18-2025, 05:52 PM
