asus ux31l Bios
  • george_gpu
    • Dec 2015
    • 77
    • greece
    asus ux31l Bios
    good day,
    i have problem with asus zenbook ux31l , it power up automatic when i put power supply ( i took off internal battery) and no bios only blank monitor .
    i think it has bricked bios .
    send me please bios file for restore
  • cacla
    • Apr 2015
    • 444
    Re: asus ux31l
    try these 2 dumps there is 2 models i dont know yours but try
    • george_gpu
      • Dec 2015
      • 77
      • greece
      Re: asus ux31l
      thanks i try
      • george_gpu
        • Dec 2015
        • 77
        • greece
        Re: asus ux31l
        Hi i make crisis disk and rename bios.wph ( BOTH BIOS TRY) \ with fn + esc & fn + b & win + r & CTRL + HOME Βut no luck
        • cacla
          • Apr 2015
          • 444
          Re: asus ux31l
          You reprogram bios?
          • george_gpu
            • Dec 2015
            • 77
            • greece
            Re: asus ux31l
            No ,
            it does n't start crisis ( rename file to bios.wph) with sequence fn + exc .....
            • cacla
              • Apr 2015
              • 444
              Re: asus ux31l
              Use programer this is full dump
              • george_gpu
                • Dec 2015
                • 77
                • greece
                Re: asus ux31l
                ok i try burn it
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • studdy05
                  Bricked HP Probook 450 G7 Bios questions
                  by studdy05
                  Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                  Ive got...
                  07-08-2025, 09:24 PM
