macbook pro a1502 ef password
    need to remove password
    Re: macbook pro a1502 ef password
    waiting
      you upload bios is corrupt.read and bkup again.
        if sure ok bios i remove try and reply.This bios try another chip I think is better.
          thanks will update here
            https://ghostlyhaks.com/blog/blog/ha...ple-efi-bypass
            This is the guide I used to remove the macbook's efi/bios password.
              this file is corrupted.can u share a working file my mobo num is 820-3476-a and emc is 2678.i tried 2 files downloaded from internet but with those notebook goes very slow
                uploads slow bios.
                  your file can not extract rezip with winrar and upload.
                    this file is corrupted.can u share a working file my mobo num is 820-3476-a and emc is 2678[B].i tried 2 files downloaded from internet but with those notebook goes very slow[
                    use the below commands for slow...
                    Shut down your Mac.
                    Locate the following keys on the keyboard: Command (⌘), Option, P, and R.
                    Turn on your Mac.
                    Press and hold the Command-Option-P-R keys immediately after you hear the startup sound.
                    Hold these keys until the computer restarts and you hear the startup sound for a second time.
                    Release the keys.
                      i tried this but it only runs for first time after that again goes slow after shutdown.slow file is attached
                        Try this and reply.
                          upload your original file for password removal.
                            above first.
                              Originally posted by imranromi View Post
                              above first.
                              That is something with his winrar because that file can not extract I tried with 7zip and winrar but can't extract
                                here you go
                                file is fine, you need newest winrar to unrar
                                Im Back... sort of...
                                  Try this and reply.
                                  thanks it work perfectly
