macbook retina A1502 emc 2835 PASSWORD REMOVE
  • basic
    • Oct 2017
    • 229
    • 86357289244
    need remove password on this model >
    A1502 emc 2835
    I WILL ATTACH ORIGINAL DUMP
  • piszpunta
    • Jan 2019
    • 260
    • poland
    Re: macbook retina A1502 emc 2835 PASSWORD REMOVE
    A1502 emc 2835
    try
    • basic
      • Oct 2017
      • 229
      • 86357289244
      Originally posted by piszpunta
      try
      i will try now and let you know
      • piszpunta
        • Jan 2019
        • 260
        • poland
        and try this
        • basic
          • Oct 2017
          • 229
          • 86357289244
          try
          this one not working
          THE SYSTEM IS DEACTIVIERT TRY AGAIN IN 60 MIN
          • piszpunta
            • Jan 2019
            • 260
            • poland
            Option+Command+P+R
            3 times
            • basic
              • Oct 2017
              • 229
              • 86357289244
              Option+Command+P+R
              3 times
              will try the second dump file
              in the first one reseting pram not working
              • basic
                • Oct 2017
                • 229
                • 86357289244
                also the second dump not working , same message the systme ist deaktiviert try in 60 min
                even with smc and pram reset ..
                  • 22276
                  Do the PRAM reset and re-install the OS .
                  • basic
                    • Oct 2017
                    • 229
                    • 86357289244
                    still same problem
                    YOUR SYSTEM SI DISABLED , TRY AGAIN IN 60 MIN
                    what wrongs here i cant understand
                    • Ghamidi
                      • Mar 2020
                      • 306
                      • France
                      still same problem
                      you need PRAM reset
                      https://www.youtube.com/watch?v=dwkZScZ3AOw
                        Apple MacBook Pro Retina 13' A1502 820-3536-A Schematic
                        Apple MacBook Pro Retina 13' A1502 820-3536-A Schematic...
                        10-12-2024, 11:43 AM
                      • MICHAEL_2013
                        Macbook Pro Core I7 A2251 EMC3348 Help Remove MDM
                        by MICHAEL_2013
                        Good afternoon. My client brought me a Mac A2251 EMC 3348 that he bought at a sale. The computer is completely iCloud-free, but it came with MDM installed. He has tried contacting the company that provides the MDM in every way possible, but they are unwilling to offer a solution. The device is:
                        Model A2251 EMC 3348. Serial Number: C02G54CZML85
                        Apple MacBook Pro Core i7 2.3, 13" 2020, 512 GB SSD, 16 GB RAM.
                        I've tried changing the serial number of the SoC ROM MX25U3235F, but it hasn't worked:
                        C02G54CZML84 only works up to Monterey.
                        C02G54CZML86 doesn't work (I...
                        11-20-2025, 11:18 AM
                      • brconta
                        MacBook A1502 EMC 2835 820-4924-A dies when installing firmware update
                        by brconta
                        I have a macbook Early 2015 A1502 EMC 2835 820-4924-A.
                        Whenever I try to update the system the device dies after reboot. It only comes back to life if the battery is disconnected, and then connected again (energy drain). Apparently the firmware update fails.
                        I can install High Sierra normally, but I can't install a newer one.
                        I can use a disk with a newer system that was installed on another machine.
                        I've already tested another chip and another bios file, but no effect.
                        Boot ROM: MBP121.0177.B00
                        SMC: 2.28f7
                        I've tried the procedure...
                        11-02-2021, 04:47 PM
                      • gbuniva
                        MacBook A1502 (820-3476-A) Repair case with solution
                        by gbuniva
                        Hi everyone, I want to share my tech experience with a MacBook Pro A1502 late 2013 that won´t turn on.
                        The computer arrived dead, when connected to Magsafe no lights on the connector.
                        Here some Measures at some testpoints on de LB 820-3476-A :
                        PP3V42_G3H 1.7V
                        PPBUS_G3H = 0V
                        PPVBAT_G3H_CHGR_RE = 0V
                        PP3V3_S5 = 0V
                        PP5V_S4 = 0V
                        P5V1_SW = 5.5V
                        PP3V3_S0SW_SSD =0V
                        PP3V3_S0SW_SSD_FET =0V
                        PPDCIN_G3H_INRUSH = 16.10V
                        PPDCIN_G3H_CHGR = 16.10V
                        PP5V_S5 - 0v
                        PP3V3_S5 - 0v
                        PP3V3_SUS - 0V
                        PM_RSMRST_L - 0v...
                        04-09-2025, 07:11 PM
                      • Miiuser
                        Macbook pro a1502 emc 2835 bios error
                        by Miiuser
                        Hello when trying to flash bios to the motherboard I get Verification error on address: 0x00000010, Device: 0xFF, Buffer: 0x5A.
                        Is there any way to fix this error?
                        Also the computer will no longer boot....
                        03-28-2023, 06:07 PM
