hp elitebook 840 g4 need password unlock
  • essaadi
    • May 2016
    • 38
    • KELAA
    #61
    Re: 840 G4 6050A2854301-MB-AO1 bios lock
    THANK YOU.
    i FOUND THE SOLUTION:
    1- OPEN BIN FILE (16MB) using 'Hex Editor Neo'
    2- Save as a copy (for example 'cleared file.bin')
    (Dont modify backup, you can need it!!!)
    3- Replace all caracters between 00b76064 and 0009c56b by 'ÿ' or 'ff' in hexadecimal.
    4- Save again
    5- Flash rom circuit using the new file 'cleared file.bin'... Enjoy
    • eikspaj
      N1NJ4W4RR10R
      • Mar 2015
      • 135
      • Philippines
      #62
      Originally posted by pipo7169
      hello
      please i need to clear pasword from hp 840 g4
      here my friend
      There are 10 types of people in the world. Those that understand binary and those that don't.
      • ismailweb
        Banned
        • Jul 2015
        • 16
        • France
        #63
        hp elitebook 840 g4 need password unlock pls clean password
        • eikspaj
          N1NJ4W4RR10R
          • Mar 2015
          • 135
          • Philippines
          #64
          Re: hp elitebook 840 g4 need password unlock
          this
          • ismailweb
            Banned
            • Jul 2015
            • 16
            • France
            #65
            Originally posted by eikspaj
            this
            thanx
            • GrahamA
              • Nov 2019
              • 9
              #66
              Can anyone tell me where the bios chip is on the HP Elitebook 840 G4 ? I've trawled through the service manual but can't see it referenced anywhere.
              Any help greatly appreciated.
              • RethoricalCheese
                • Mar 2013
                • 1517
                • Estonia
                #67
                Did you even open up the laptop?
                There are 2 EEPROMs right next to the RTC battery. I think they are in WSON8 package on that model so unless you have a better way, they must be unsoldered to read/write.
                Anyway, the larger sized EEPROM is main bios. Probably 25Q128 written on it.
                • Nico Latour
                  Banned
                  • Sep 2019
                  • 52
                  • france
                  #68
                  840 g4 chip is left near the bios battery (you can desolder or use old soic clip and cut off small plastic and hold on pads near chip
                  • GrahamA
                    • Nov 2019
                    • 9
                    #69
                    Perfect - thanks guys - I thought that was the one - I’m trying to use a clip but having a few problems - I’ll try again :-)
                    • GrahamA
                      • Nov 2019
                      • 9
                      #70
                      I've attached a picture of the chip ... does this look correct ?
                      • GrahamA
                        • Nov 2019
                        • 9
                        #71
                        I'm still on this - I can't get the SOIC clip to connect - what bits are you suggesting I cut off ?
                        • Nico Latour
                          Banned
                          • Sep 2019
                          • 52
                          • france
                          #72
                          BANNED
                          • GrahamA
                            • Nov 2019
                            • 9
                            #73
                            send me pm or conta**********ct********hen i show you pics
                            Pm’d - many thanks
                              • 20682
                              send me pm or c**********************ow you pics
                              assistance is best done in public
                              • RethoricalCheese
                                • Mar 2013
                                • 1517
                                • Estonia
                                #75
                                If you want to read HP eeproms onboard with a clip you need to first unplug battery. Plug charger. Turn on laptop (go to F1 screen or bios, doesnt matter). Turn off laptop but keep charger plugged in. And now connect your clip and programmer. This way it almost always works fine.
                                But the one you sent a pic of is not correct. It is the other one with 128 written on it, not 64.
                                • GrahamA
                                  • Nov 2019
                                  • 9
                                  #76
                                  I'm obviously new to all this and doing things the wrong way.
                                  The clip I'm trying to use is attached to a Raspberry PI - I thought that gave it all the power it needed ?
                                  In the hope of getting to the bios chip a bit better I've removed the motherboard.
                                  I've take pictures of the chip - I've no idea how to get a clip on this so contact is made correctly and unsure whether I can heat gun the chip off the board.
                                  Has anyone any experience of dealing with a similar chip ?
                                  • RethoricalCheese
                                    • Mar 2013
                                    • 1517
                                    • Estonia
                                    #77
                                    Either you need to unsolder it or solder wires on the large pads around the chip.
                                    • GrahamA
                                      • Nov 2019
                                      • 9
                                      #78
                                      I managed to get it off the motherboard and flashed it using my Pi - unfortunately on reconnecting everything the laptop doesn't turn on - so I guess I've messed something up somewhere.
                                      I may give up.
                                      The power light (the main one on the switch) and the Caps Lock light go off then come on again in a cycle.
                                      I've had a hunt for whether this means something but am find mixed answers.
                                        • 20682
                                        It looks like you`ve knocked a part off the board.Check the traces as well for continuity,you might have cut through one of them.
                                        • GrahamA
                                          • Nov 2019
                                          • 9
                                          #80
                                          I'll have a look - there's a strong possibility the bios chip isn't sat quite in the right place - it just sits on top of the board rather then having legs going through it - so getting it in the right place seems like a bit of hit and miss...
                                          • moshu
                                            HP EliteBook 755 G4 bios password locked
                                            by moshu
                                            Hi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
                                            I've read the 16MB chip and patched using ​RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
                                            Can you please help to remove the password?
                                            after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
                                            HP EliteBook 755 G4
                                            ProdID: W5Q98AV
                                            SN: 5CG7524BY4...
                                            02-01-2025, 06:59 AM
                                          • Modify_inc
                                            Locked Setup Fails to Unlock with Correct Password - Inspiron 11 3185
                                            by Modify_inc
                                            I have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...
                                            11-02-2021, 11:14 AM
                                          • marc_ytos
                                            request unlock HP EliteBook 640 G11 password bios
                                            by marc_ytos
                                            Greetings, please request help to unlock 640 G11 password bios DA0X8VMB8G0 serial number 5CD4392RDF thank you very much in advance...
                                            01-11-2025, 06:20 PM
                                          • ibo
                                            Elitebook 655 G10 Bios Password Unlock
                                            by ibo
                                            Can somebody unlock this bios?
                                            Serial 5cd329740h...
                                            10-18-2024, 10:00 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
