request unlock HP EliteBook 640 G11 password bios
  • VirVir
    • Apr 2024
    • 12
    Hello everyone! I have this Laptop with a locked BIOS 😔 I've tried unlocking the EC file but it's "Missing unlockable content" so...main BIOS, split in 2x16Mb files, RCUnlocker said it's unlocked, spits a *_unlocked.bin file, reunite the flies in a 32Mb file but... nothing changed. Verified with CMD certutil -hashfile but it's the same file as the original 🤷🏻 what's up with that? Can someone please help? 🙏🏻 Thank you 🙏🏻
    5CD4441CK3 B3FD3EC#ABD
    MODEL:X8V
    DA0X8VMB8G0 REV.G
    • hoaca388
      Badcaps
      • Jan 2022
      • 11729
      MODEL:X8V
      DA0X8VMB8G0 REV.G
      HP EliteBook 640 14 inch G11 Notebook PC
      CT Number_6TDWV0B81K2L4R
      Serial_5CD4441CK3
      Sku_B3FD3EC#ABD
      Build Id_24WWREBZ601#SABD#DABD
      Fearture byte_476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAeMfPguhKhkjhk8mEmVn7nVpDpTpnpqprqDqzrNrXrbs4.yF
      Hope it unlocks. Goodluck.
      • VirVir
        • Apr 2024
        • 12
        Serial_5CD4441CK3
        Sku_B3FD3EC#ABD
        Unfortunately doesn't work 😔 Some error appeared telling me that the BIOS makes some recovery from the embedded memory due to mismatch ID information...only one option and that was to click "OK" , after 2 minutes the laptop restarted and the password is still there. This is so annoying 😖😖😖 Anyway, thank you for helping!
        • VirVir
          • Apr 2024
          • 12
          Tried another way. Basically I've replaced the entire ME Reg part of the BIOS with info from a Firmware recovery file from the HP site. After more than one hour everything was done 👍🏻 Laptop starts and...informed me about the mismatched information and that it's doing a quick recovery ... after two restarts, the password is there of course 😖😖😖 How the h*LL can I stop it from doing this sh*t recovery? I didn't find any cmos battery on this model, the power is out long enough....How does it remember?😢😢😢
          • mesdova
            • Oct 2015
            • 24
            • algeria
            Originally posted by mesdova
            need unlock and patch
            HP ELITEBOOK 640 G11
            SN: 5C4377dfl
            PRODID: 901d4av
            bump
            • rex98
              • Feb 2023
              • 1277
              • Mandaue CEBU, Philippines
              #26
              can someone test this use the 1st one
              if it doesn't work use the second one.
              you should flash both main and EC
              and let me know if it boots to MPM thanks.
              • VirVir
                • Apr 2024
                • 12
                Hello guys! Found some troubling info about the HP security from 2024 onward:
                HP Endpoint Security Controller 2024
                Attacks against PC firmware are on the rise. Unfortunately, protecting the PC BIOS and other critical firmware is often not seen as a priority. HP addresses this with our Endpoint Security Controller (ESC), a dedicated chip that validates the integrity of the BIOS and other firmware to enhance the security of every HP business-class PC. The ESC validates that the firmware is not infected by malware before the CPU is allowed to boot. If any corruption has been detected, it will restore a clean copy held in the ESC's isolated flash. HP is the only vendor offering this unique security solution as a standard part built into business-class PCs to safeguard our customers against IT security threats.
                Bottom line is...no matter if you can "unlock" the main BIOS as long as the ESC provide a backup and restore the old blocked BIOS before you can access it...
                • rex98
                  • Feb 2023
                  • 1277
                  #28
                  i know there's always a way. we haven't tried it yet. every security there's always a loophole. like this in g11 EC its very similar VSSTORE in bios main i haven't tried this yet, if i only have G11 laptop here i would try all possible means.
                  • VirVir
                    • Apr 2024
                    • 12
                    You mean, that part should be replaced with FF or 00? For the moment I've gave up, due to lack of time and, after writing and rewriting the BIOS chip 4-5 times...it said enough and burned... I'm waiting for an order of 10 chips from AliExpress but it will take some time. Keep it touch 🤘🏻🖖🏻
                    • rex98
                      • Feb 2023
                      • 1277
                      #30
                      you should not remove the chip if just testing, just put jumper wire and use ISP in rf809f or h.
                      • black0hackers
                        • Jul 2020
                        • 367
                        I HAVE TEST 2 FILE. 1ST WORK BUT NOT BOOT TO MPM, STILL HAVE PASSWORD, 2ND DONT WORK
                        i have one 640 g11 bios pass
                        SN: 1H850824LY
                        PROD ID: A58TVUC#ABA
                        • zenius
                          by zenius
                          12-08-2024, 06:13 AM
                        • overclocker1786
                          [Bios Password Unlock Request] [Dell OPTIPLEX SFF PLUS 7020] [8FC8 method]
                          by overclocker1786
                          Hello I have a dell optiplex SFF plus 7020 with a password that I recovered from e-waste. It is possible to get the password removed via the bios patch method? I managed to dump the 32MB bios chips and would like help patching it to MFG mode so I can clear the password.
                          Thanks.
                          1hj4z24 = Service tag
                          A schematic would also be amazing if anyone has one!...
                          08-31-2024, 08:46 PM
                        • traxformania
                          TONGFANG "GM7TG7P" Bios Password Problem?
                          by traxformania
                          I tried :
                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                          11-15-2023, 07:32 AM
                        • BlackVisor
                          How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                          by BlackVisor
                          RedmiBook Pro 1542022 6800H
                          SKU: TM2113-39463
                          Model Number: RMA2204-AB
                          CMIIT ID: 2022AP1835
                          SN: 39463/22WD01355
                          BIOS version: RMARB5B0P1010 20230628
                          1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                          2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                          3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                          01-14-2024, 06:35 AM
                        • outsider
                          Panasonic FZ-G1 MK5 - BIOS password returning
                          by outsider
                          Hello
                          I removed the BIOS password thanks to the help of one of the friends of this forum.
                          https://www.badcaps.net/forum/troubl...61#post3637661
                          The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                          06-17-2025, 12:51 AM
