hp elitebook 840 g4 need password unlock
Last edited by SMDFlea; 04-10-2023, 12:39 PM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs. -
Re: hp elitebook 840 g4 need password unlock
https://www.badcaps.net/forum/showthread.php?t=103184
>Last edited by SMDFlea; 04-10-2023, 12:39 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Every donation made will go towards server fees and maintenance costs.Comment
hi i have this EliteBook 840r G4 6050A2939701-MB-A01 32mb main and 16mb ec, i tried rculnocker but give me an error ,and points me to check for 16mb file i tried but no success, and using other dump password is gone but displays embedded controller mud data not match, any ideas how to resolve this case?Last edited by SMDFlea; 04-10-2023, 12:39 PM.Comment
Hi All... Quick question regarding the BIOS chips and password. The notebook Im trying to unlock has a POST POWER-ON PASSWORD on it, which I presume is different to a BIOS Password.
I read somewhere that this password actually lives in the 25Q64JV1Q rom, not the 25Q128JVPQ rom where normal passwords live.
Is any one able to verify which Rom does the POST Power-On password live?
Thanks..Comment
Thanks..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
hi i have this EliteBook 840r G4 6050A2939701-MB-A01 32mb main and 16mb ec, i tried rculnocker but give me an error ,and points me to check for 16mb file i tried but no success, and using other dump password is gone but displays embedded controller mud data not match, any ideas how to resolve this case?↵
https://www.badcaps.net/donateComment
try this...the 8MB bios doesn't seem to have the password...just write it to the 16MB one, the 8MB one stays the same..Last edited by SMDFlea; 04-10-2023, 12:39 PM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Hi guys, I am currently struggling with my HP Elitebook 840 G4 which I bought used on ebay several years ago. All of a sudden I got an error message "DeviceFreeze 0586" I already found out, that it has to do with Absolut Software within the BIOS and even when I delete the services and files the software installs itself. In the UEFI there are read only settings to disable it, but idk how to change them. Is there anything that you guys can do to help me? BIOS dump is attached.Last edited by SMDFlea; 04-10-2023, 12:39 PM.Comment
Hi guys, I am currently struggling with my HP Elitebook 840 G4 which I bought used on ebay several years ago. All of a sudden I got an error message "DeviceFreeze 0586" I already found out, that it has to do with Absolut Software within the BIOS and even when I delete the services and files the software installs itself. In the UEFI there are read only settings to disable it, but idk how to change them. Is there anything that you guys can do to help me? BIOS dump is attached.↵
It is the BIN file I extracted from the system using the "HP System BIOS Update Utility" and its "Backup" function. Do I have to use a different method? Sorry for the inconvenience if I did something wrong.Comment
This is not a complete bios file, you need a device to read the bios chip, learn about CH341A programmer, it is the cheapest one.↵
Thank you for the information, I guess I was a little to naive, thinking this could be done by simply posting the bios flash update file. I will look into the procedure.Comment
by moshuHi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
I've read the 16MB chip and patched using RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
Can you please help to remove the password?
after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
HP EliteBook 755 G4
ProdID: W5Q98AV
SN: 5CG7524BY4...-
Channel: BIOS Requests ONLY!
by Modify_incI have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...
by marc_ytosGreetings, please request help to unlock 640 G11 password bios DA0X8VMB8G0 serial number 5CD4392RDF thank you very much in advance...
- Loading...
