Remove_SMM... UEFI.
  • Knucklegrumble
    • Jun 2020
    • 78
    • US
    #1041
    Re: T440p Please deactivate or disable computarce in given bios
    Originally posted by kamalkharbanda
    Its grayed out (computrace function only)
    Honestly I believe the problem is that there is some other security password that is required before you get to the supervisor password. Does it have the power-on password enabled?
    EDIT: I've done some quick googling... Your board is locked by Anti-Theft. This patch won't help you with that.
    • kamalkharbanda
      • Jun 2013
      • 92
      • India
      #1042
      Yes my board is locked by Anti Theft.
      what is the solution for this
      • Karol
        • May 2016
        • 90
        • Romania
        #1043
        Re: Remove_SMM... UEFI.
        Upload a short video on YouTube. Let see what is "gray"
        Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1355
          • France
          #1044
          put a password, patched the bios, it removes the Anti Theft
          • Knucklegrumble
            • Jun 2020
            • 78
            • US
            #1045
            I don't think he can put a password... He's locked out of the settings.
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1355
              • France
              #1046
              I have already made several like that. The anti theft box is grayed out but we can put a password. It must be patched after that and the box becomes blue again with the choice enable or disable.
              it must have a message when opening the setup if the pc is linked by anti theft
              • Knucklegrumble
                • Jun 2020
                • 78
                • US
                #1047
                Oh ok.
                What happens if there is anti-theft AND there is already a SV password?
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1355
                  • France
                  #1048
                  it also unlock with bios patched
                  • Knucklegrumble
                    • Jun 2020
                    • 78
                    • US
                    #1049
                    Can someone with deeper knowledge than mine explain why the 9th generation can't be unlocked with a patch like this one?
                    • AAAC
                      • Jan 2020
                      • 459
                      • Mexico
                      #1050
                      @Knucklegrumble
                      The way I see the problem is like this:
                      ThinkPad 9th Generations models (not all) have this "Self-Healing" bios, 32MB (or 256mbit) chip, which store the current bios and the previous (backed-up) bios, so when you modify the firmware, the modification is detected when it fails hash/signature verifications during power-on, then ThinkPad will "self-heal" with the backup bios, the patched files are never executed. If you modify both bioses computer will not POST.
                      Do you have a 9th Gen ThinkPad to test? Give it a try and you'll see.
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1355
                        • France
                        #1051
                        [QUOTE=Maxpower3]
                        Originally posted by superhansi
                        i dont have patched 32mb file that does unlock the SVP, it boots but the behavior is the same as unpatched (despite the fact a known PW isnt working, but thats common for all imho)
                        What i know is, that they extended the bytes in MEC that belong to the pw (usually its 16byte + checksum, now its 32byte + checksum).
                        The trick for new gen isnt working in 9th gen
                        I didnt even find someone who is selling 9th gen, they all ask to send device in (probably they program the MEC with jtag) or say that its not for selling...
                        • b4rdock
                          • Jun 2017
                          • 106
                          • usa
                          #1052
                          hi,an help patch this x240 ?
                          please
                          • b4rdock
                            • Jun 2017
                            • 106
                            • usa
                            #1053
                            please
                            here dump
                            • Knucklegrumble
                              • Jun 2020
                              • 78
                              • US
                              #1054
                              Originally posted by AAAC
                              @Knucklegrumble
                              And @Maxpower3
                              Thank you both for the explanation. I don't have a 9th gen currently on hand but I might be able to get one at some point to try it out. I'm curious to see if anything can be done.
                              • Knucklegrumble
                                • Jun 2020
                                • 78
                                • US
                                #1055
                                Try using this and report please https://www.badcaps.net/forum/showthread.php?t=87588
                                • Knucklegrumble
                                  • Jun 2020
                                  • 78
                                  • US
                                  #1056
                                  @Knucklegrumble
                                  According to this post they can unlock 9th gen with their patch (ie. T490)... So what am I missing here? I'm confused...
                                  https://www.allservice.ro/forum/view...b82c079d88c277
                                  • AAAC
                                    • Jan 2020
                                    • 459
                                    • Mexico
                                    #1057
                                    @Knucklegrumble
                                    They don't mention anything about patching for latest models, it says:
                                    "P1, X1 Tablet Gen3, L390, X390, P53, T490, T495, T590, X1 Extreme Gen1, X1 carbon gen7 - some of these momentarily only available in our service shop."
                                    Off the list, I know that T495 can be patched and unlocked using Dxe driver, also: ThinkPad E490, ThinkPad E490s and ThinkPad E590 (these 3 use same bios file).
                                    Contact them, depending on the model they may ask you to ship ThinkPad to them.
                                    • Knucklegrumble
                                      • Jun 2020
                                      • 78
                                      • US
                                      #1058
                                      @Knucklegrumble
                                      Ah you're correct... In the second post where they list the T490 they say that some models are only available in their shop... I really need to get my hands on a 490 and poke around some... Lol
                                      • JOHNLAG7
                                        • Nov 2014
                                        • 20
                                        • Greece
                                        #1059
                                        Please can someone patch this for x1 6th
                                          • 21960
                                          Try the auto-patcher ,read the instructions in the first post
                                          • GuiTi
                                            Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
                                            by GuiTi
                                            Hey everyone!
                                            I need help with my Lenovo Chromebook 100e Gen 3.
                                            Here are the details:
                                            • Motherboard: LA-L131P
                                            • MFG Date: 2022/01/07
                                            • MTM: 82J80001BR
                                            • MO: MPNXB2103001
                                            • Factory ID: LI123
                                            I bought a new Winbond 25Q128FVSG chip.
                                            The chip currently on the board is the same model but with different ending letters.
                                            I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
                                            The Chromebook is Google account locked, and I’ve already tried everything.
                                            I understand that I need to replace or...
                                            10-14-2025, 08:41 AM
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
