Unconfigured Ad
Remove_SMM... UEFI.
  • RethoricalCheese
    • Mar 2013
    • 1514
    • Estonia
    #141
    Re: Remove_SMM... UEFI.
    No, it should ask to press space twice. Maybe it hangs for some reason.
    • dwirachmat
      • Sep 2015
      • 7
      • indonesia
      #142
      Your patch is stuck, not continue on the next prosess
      When i check your file with ida, the file is not modified.
      • dwirachmat
        • Sep 2015
        • 7
        • indonesia
        #143
        I have modified by my self. And it working. Success to remove password x250. Just replace BE in hex editor into 00 according address on ida pro.
        • dwirachmat
          • Sep 2015
          • 7
          • indonesia
          #144
          • mehar
            • Feb 2015
            • 12
            Than share your patch bro.
            • RethoricalCheese
              • Mar 2013
              • 1514
              • Estonia
              #146
              Could somebody send me patched bios file that has 6, 8, 9 or 10 digit Hardware ID?
              • biospwd
                Banned
                • Oct 2019
                • 51
                • Ireland
                #147
                I can't find SystemPipsNeededbyDXE << where is this . Someone can copy GUID number for this SystemPipsNeededbyDXE ?? Im check file line by line but i cant find. Meybe this name is wrong ?
                • RethoricalCheese
                  • Mar 2013
                  • 1514
                  • Estonia
                  #148
                  You don't need it anyway if you use uefitool.
                  And it does not excist on newer models anyway.
                  • biospwd
                    Banned
                    • Oct 2019
                    • 51
                    • Ireland
                    #149
                    OK, i'm use UefiTool but my patch PE32 in (LenovoTranslateService and in BootOptions) works on many model L serries and T but in X1 Carbon 4 th (laptop start and beeps and not happend and turn off ) i use lock key and SSD ATA locked.
                    So looks like I need to change something else but what?
                    • coumcoum
                      • Dec 2015
                      • 36
                      • algerie
                      #150
                      have you generator key ?
                      • biospwd
                        Banned
                        • Oct 2019
                        • 51
                        • Ireland
                        #151
                        This is not answer about my question.
                        No i don't have generator. Someone can help with X1 Carbon 4th patch ?? how to make in this case ?
                        • Killah
                          • Oct 2019
                          • 5
                          • United Kingdom
                          #152
                          hiya bud thanks for the reply
                          the link doesnt work getting a 403 Forbidden error on it
                          • Killah
                            • Oct 2019
                            • 5
                            • United Kingdom
                            #153
                            got it needed to proxy it ill give it a try thanks
                            • aliencillo
                              • Oct 2019
                              • 6
                              • SPAIN
                              #154
                              five beeps and power off?
                              If you have updated the bios recently read this
                              https://www.bios-mods.com/forum/Thre...onger-possible
                              https://www.insanelymac.com/forum/to...eps-on-lenovo/
                              • biospwd
                                Banned
                                • Oct 2019
                                • 51
                                • Ireland
                                #155
                                5beeps pause 5beeps
                                • Killah
                                  • Oct 2019
                                  • 5
                                  • United Kingdom
                                  #156
                                  thanks biospwn got that working
                                  can confirm file works on lenovo 440s
                                  • smok92
                                    • Oct 2015
                                    • 27
                                    • Polnad
                                    #157
                                    Can anyone help me modyfi my x1 3gen bios. When i try after enter key laptop stop response.
                                    • smok92
                                      • Oct 2015
                                      • 27
                                      • Polnad
                                      #158
                                      Success, this file work
                                      • anshad
                                        • Nov 2010
                                        • 249
                                        #159
                                        This is for X1 5th Gen or 3rd Gen ?
                                        • biospwd
                                          Banned
                                          • Oct 2019
                                          • 51
                                          • Ireland
                                          #160
                                          I was check dump it's for ThinkPad X1 Carbon 3rd.
                                          Someone help my with X1 Carbon 4 th :
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
                                          • hinsech475
                                            Fujitsu LIFEBOOK AH562-UEFI problem-Help request
                                            by hinsech475
                                            Hi, I would appreciate your help with the following problem.
                                            I have a Fujitsu laptop AH562 witn a BIOS-UEFI problem since I converted the HDD to a SSD. For more details on the paltop go to the following link:
                                            http://support.fujitsupc.com/CS/Port...srch=TECHSPECS
                                            After copying the HDD to SSD with ALtiris utility provided with the Kingston SSD and replacing the HDD with the SSD the laptop went into a startup loop with no screen display and only the disk LED flashing twice per second. I waited for approximatly 2h and then stopped the laptop...
                                            06-03-2018, 10:57 PM
