asus GL552V-X bios
  • teqcom
    • Nov 2015
    • 311
    • malasyia
    asus GL552V-X bios
    need bios
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: asus GL552V-X
    Just download the update file from asus site and replace bios region in original bios with web update using uefitool, or else post the non working bios here.
    • cacla
      • Apr 2015
      • 444
      Re: asus GL552V-X
      Try this one and if this dont work sent me sn for notebook
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • davidebeatrici
        Asus X541UV Windows update KB5063060 deleting BootOrder EFI environment variable? bios fix
        by davidebeatrici
        I had 3 people contact me in a week because Windows suddenly didn't boot:
        As you can see, all 3 are ASUS computers, but I believe the common factor is the BIOS being American Megatrends (AMIBIOS/APTIO).
        The first two recovered just fine after a restart, but the third one didn't and was brought to me. The model is F541UV (X541UV).
        Setup allows to add a boot option manually and the operating system boots just fine from both bootx64.efi and bootmgr.efi. However, there is no way whatsoever to save the option(s): upon a reboot the machine goes straight...
        06-17-2025, 12:59 PM
      • jinki_dadou
        ASUS ExpertCenter D700MD need update bios
        by jinki_dadou
        helle
        in have asus desktop
        model : D700MD-5124000950
        CPU i5 12400
        I wanted to upgrade the processor i7 13700
        when I change the processor show black screen and fan spinning fast
        i ask asus technical support
        the answer : include microcode in the latest update bios
        he give me file 1 update bios
        2 microcode
        2 fils in tha attachments please help me
        ( sorry for my dab english )...
        05-18-2025, 02:20 AM
      • mikeybass
        by mikeybass
        04-23-2025, 04:30 PM
