need bios dump for asus x751sa
  • alas3376
    • Nov 2011
    • 382
    • BENIN
    hello,
    i need this bios dump for asus X751sa rev. 2. 0
    thank you
  • Francisco.s
    • 686
    • Spain
    Re: need bios dump for asus x751sa
    Upload your backpup in order to merge it whit the one from Asus website.
    • alas3376
      • Nov 2011
      • 382
      • BENIN
      here is the old one dumped
      • alas3376
        • Nov 2011
        • 382
        • BENIN
        help!!!!!!!!!!!!
        plz
        • alas3376
          • Nov 2011
          • 382
          • BENIN
          help!!!!!!
          • Francisco.s
            • 686
            • Spain
            here you are.
            • alas3376
              • Nov 2011
              • 382
              • BENIN
              thank you Mr Francisco.s
              i will try it and let u know
              • alas3376
                • Nov 2011
                • 382
                • BENIN
                not work
                • Francisco.s
                  • 686
                  • Spain
                  Originally posted by alas3376
                  not work
                  What's the initial problem?
                  • alas3376
                    • Nov 2011
                    • 382
                    • BENIN
                    Thank you Mr Francisco. S, when u connect the charger the charger start flashing. And nothing When u press power botton
                    • Francisco.s
                      • 686
                      • Spain
                      Is there any voltage in power button pins? and in bios chip?
                      • cacla
                        • Apr 2015
                        • 444
                        try this one
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Do you mean power indicator light on the adapter itself is blinking???
                          • String2016
                            • Nov 2015
                            • 2238
                            • philippines
                            thats not the bios issue just checked first the 19v rail i think there is short
                            • alas3376
                              • Nov 2011
                              • 382
                              • BENIN
                              thank everybody for aswering, Mr Calca i will try it and let you know.
                              Mr Francisco,there is 3.3V on the power boton.
                              Mr mcplslg123, i mean power led on the motherboard .
                              it seem to be bios issue. plz
                              • Francisco.s
                                • 686
                                • Spain
                                how about the new bios?
                                • alas3376
                                  • Nov 2011
                                  • 382
                                  • BENIN
                                  hello mr Francisco, i tried the new bios but nothing, the state remain the same.
                                  i think i need the ec dump for this. it's an IT8885E
                                  • ala_borbe
                                    aka Donald
                                    • 1625
                                    • Malta
                                    here you go, bios fixed
                                    if you still have same problem its not the bios
                                    board X751SA
                                    Im Back... sort of...
                                    • Francisco.s
                                      • 686
                                      • Spain
                                      Try it and post result.
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • razor_amd
                                        by razor_amd
                                        12-15-2020, 07:07 PM
                                      • DynaxSC
                                        by DynaxSC
                                        06-14-2024, 03:49 PM
                                      • ArkzG
                                        [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                                        by ArkzG
                                        Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                                        What I currently have available:
                                        - Model: FA506NF (2021)
                                        - BIOS chip: GD25LQ16 (16Mbit/2MB)
                                        - Tools: CH341A programmer ready to use
                                        Does anyone have either a clean 2MB .bin dump of this model,...
                                        09-26-2025, 09:34 PM
                                      • kodox
                                        Asus ExpertBook B1400CB Bios Dump Needed
                                        by kodox
                                        need original bios dump, original bios has flashed by other technician before me.
                                        attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                                        unit info:
                                        Model: Asus ExpertBook B1400CBA-0711A1235U
                                        S/N: R6NXNZ006657238
                                        CN: 7F6F
                                        Mainboard Code: B1500CBA R2.1...
                                        08-16-2025, 12:20 PM
