Lenovo T450 and Computrace
  • CygnusX1
    • Aug 2017
    • 7
    I am trying to disable Computrace on a T450 I had bought. Does Computrace live in the BIOS and if O replace the BIOS will I be able to disable it?
    Any help would be great!
  • mielta
    • Apr 2015
    • 368
    Re: Lenovo T450 and Computrace
    http://thinkwiki.de/Computrace
      • 31283
      it's 4 bios modules.
      let us know if you get that spyware out without bricking the laptop - i tried once and failed.
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        ^ Did it on the t520 myself....
        Follow the white rabbit.
          • 31283
          good - then you can explain the method
          • CygnusX1
            • Aug 2017
            • 7
            Do tell how then...
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              Originally posted by CygnusX1
              Do tell how then...
              https://www.coreboot.org/
              Interestingly enough, after i had built coreboot and had it running for a while, i was able to flash a BIOS ROM i got on this forum that had computrace inactive, and it was disableable as of first boot.
              • marsupial.path
                • Dec 2016
                • 14
                • papua new guinea
                hii, can you share bios rom you got from that forum that had computrace inactive??
                because i have same problem with you.. t450 with computrace active and cannot disabling...even this bios isn't password locked..
                i post my backup bios maybe some can help me...
                thank you
                • rachid34000
                  • Jan 2015
                  • algeria
                  i have a solution about thinkpad bios password 4, 5, 6, and 7 generation
                  • user212dan
                    • Jul 2017
                    • 23
                    • Bulgaria
                    can you share it ?
                    • CraterM
                      • Mar 2018
                      • 180
                      • Moldova
                      Originally posted by user212dan
                      can you share it ?
                      Put bios dump here!
                      • szupak
                        • Aug 2016
                        • 7
                        • Poland
                        Originally posted by CraterM
                        Put bios dump here!
                        Hello. I have T470 with computrace. Can you help me to unlock it?
                        Thank you!
                          • 22109
                          Thank you!
                          Off topic, read the thread title - "Lenovo T450 and Computrace" .Start your own thread or find a T470 thread to post in .
                          • lucaszmn
                            by lucaszmn
                            Problem:
                            Initial Findings:
                            • I concluded that the
                            08-12-2025, 03:01 PM
                          • Wahaz
                            by Wahaz
                            10-30-2023, 08:42 PM
                          • grimacelord
                            Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                            by grimacelord
                            Hello there.
                            I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                            History:
                            1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                            I searched for this error online and discovered...
                            03-15-2023, 03:29 PM
                          • to5it0
                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                            by to5it0
                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                            I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                            This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                            I have opened the laptop and identified the main BIOS chip...
                            10-24-2025, 01:35 AM
                          • mkdj
                            Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                            by mkdj
                            Dear all,
                            I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                            Here the steps I have taken to fix the laptop:
                            - downloaded latest BIOS from Lenovo Website...
                            10-18-2025, 03:43 AM
