Asus X541UVK Bios
  • Pascal Komlassan
    • Jan 2017
    • 805
    • TOGO
    Asus X541UVK Bios
    hello please i need the bios dump of this Asus Main board X541UVK REV: 2.0
  • robgerr
    • Apr 2012
    • 70
    • Italy
    Re: Asus X541UV Bios
    go here :
    https://www.elvikom.pl/asus-f541u-pl...8.html#p190437
    see the post for modify address hex for key of windows serial
    • bumper1
      • Jul 2014
      • 72
      • Poland
      This is the file (I put it on elvikom). I changed windows key there to xxxxx-xxxxx-.... but this should work like it is.
      • Pascal Komlassan
        • Jan 2017
        • 805
        • TOGO
        ok thank's bro
        • Pascal Komlassan
          • Jan 2017
          • 805
          • TOGO
          Any help ?
          • int-plus
            • Jul 2018
            • Kazakhstan
            friend, "SOOOOOOO" Thanks you
            • cacla
              • Apr 2015
              • 442
              Here it is
              • muaadc
                • Jul 2017
                • 3
                • india
                asus x541uvk it8995e bios please
                • amsicctv
                  • Feb 2019
                  • Argentina
                  thanks you save my!!!
                  • johnbad
                    • Jul 2013
                    • 4
                    • Romania
                    Try this
                    • emicronet
                      • Sep 2014
                      • 10
                      • españa
                      • Claudiomfa
                        • Nov 2015
                        • 455
                        • Portugal
                        Hi @muaadc,
                        You change de key only in one location. On this bios you have two key locations. Check again. 66PHD
                        • Bybuca35
                          • Apr 2017
                          • 11
                          • VVVvvv
                          Asus X541UVK REV 2.0
                          hello my friend (Asus K541U ) anakart kodu ( X541UVK REV 2.0 ) clear bios: Ağlayan:
                          • peste
                            • Dec 2016
                            • 12226
                            • ROMANIA
                            Re: Asus X541UVK REV 2.0
                            https://www.badcaps.net/forum/showthread.php?t=64225
                            • Bybuca35
                              • Apr 2017
                              • 11
                              • VVVvvv
                              they did not work
                              • Bybuca35
                                • Apr 2017
                                • 11
                                • VVVvvv
                                Re: Asus X541UVK REV 2.0 bios dump neededd
                                plsss
                                • cellphoneyeta
                                  ShortedboardGSM
                                  • Oct 2015
                                  • 49
                                  • philippines
                                  Please clean my orig bios ASUS X541U. Download here:
                                  Thanks in advance
                                  • cellphoneyeta
                                    ShortedboardGSM
                                    • Oct 2015
                                    • 49
                                    • philippines
                                    I used this bin file, and it works on my ASUS with bios password.
                                    Only why it says charging 96percent, but the unit turned off when unplug the charger. Also it can't be on with the battery..
                                    • Vesko356
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      Hahah, the guy obviously has to learn more things, but is going in the right direction.
                                      Become a Badcaps supporter
                                      Thanks to all supporters.​
                                      • maurivi22
                                        • Dec 2019
                                        • españa
                                        it is compatible with motherboard x541uv without "k"?, I have a laptop x541ua with motherboard x541uv rev 2.0
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          Yesterday, 05:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • davidebeatrici
                                          Asus X541UV Windows update KB5063060 deleting BootOrder EFI environment variable? bios fix
                                          by davidebeatrici
                                          I had 3 people contact me in a week because Windows suddenly didn't boot:
                                          As you can see, all 3 are ASUS computers, but I believe the common factor is the BIOS being American Megatrends (AMIBIOS/APTIO).
                                          The first two recovered just fine after a restart, but the third one didn't and was brought to me. The model is F541UV (X541UV).
                                          Setup allows to add a boot option manually and the operating system boots just fine from both bootx64.efi and bootmgr.efi. However, there is no way whatsoever to save the option(s): upon a reboot the machine goes straight...
                                          06-17-2025, 12:59 PM
                                        • lrouw84
                                          by lrouw84
                                          Hi there,
                                          01-28-2023, 01:31 PM
