ASUS N750JK Bios dump
  • nixi22
    • May 2016
    • 44
    • Croatia
    Dose anyone have bios dump for asus n750jk, machine is fixed by flashing n750jv bios that i find online but now i can't see gtx860m only integrated Intel one.
  • nixi22
    • May 2016
    • 44
    • Croatia
    Re: ASUS N750JK Bios dump
    After some time i manage to find working dump for 750jk and after flash 860m is detected and working
    • Aleksandr49
      • Jul 2020
      • Израиль
      Thank you very much for the file, but this is a revision 2.1 file N750JK REV-2.1
      • barbados
        • Mar 2021
        • Hungary
        Thank you very much BIOS dump.That's exactly what I needed!
        • SAF1
          • Sep 2022
          • 6
          • Ghana
          It worked for me too, thanks
          • Sami Wahid
            • Oct 2015
            • 78
            • Morocco
            Hello, Please I need EC dump
            • peste
              • 13924
              • ROMANIA
              post S/N, full name and model, motherboard model,etc.
              post the original contents of the bios chip..post EC if possible..
              why don't you respect the forum rules..you have 73 posts..you are not a beginner here...you are "eating" our time
              • Sami Wahid
                • Oct 2015
                • 78
                • Morocco
                I'm Sorry, bro.
                MODEL: N750JK-T4175H
                S/N: E6N0CY210904258
                Board: N750JK MAIN BOARD REV 3.0
                I don't have any backup
                • mkdj
                  by mkdj
                  Dear all,
                  10-19-2025, 04:41 AM
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • pirati
                  by pirati
                  10-27-2025, 04:20 PM
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
