ASUS N750JK Bios dump
  • nixi22
    • May 2016
    • 44
    • Croatia
    Dose anyone have bios dump for asus n750jk, machine is fixed by flashing n750jv bios that i find online but now i can't see gtx860m only integrated Intel one.
  • nixi22
    • May 2016
    • 44
    • Croatia
    Re: ASUS N750JK Bios dump
    After some time i manage to find working dump for 750jk and after flash 860m is detected and working
    • Aleksandr49
      • Jul 2020
      • Израиль
      Thank you very much for the file, but this is a revision 2.1 file N750JK REV-2.1
      • barbados
        • Mar 2021
        • Hungary
        Thank you very much BIOS dump.That's exactly what I needed!
        • SAF1
          • Sep 2022
          • 6
          • Ghana
          It worked for me too, thanks
          • Sami Wahid
            • Oct 2015
            • 77
            • Morocco
            Hello, Please I need EC dump
            • peste
              • Dec 2016
              • 12944
              • ROMANIA
              post S/N, full name and model, motherboard model,etc.
              post the original contents of the bios chip..post EC if possible..
              why don't you respect the forum rules..you have 73 posts..you are not a beginner here...you are "eating" our time
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • kodox
                Asus ExpertBook B1400CB Bios Dump Needed
                by kodox
                need original bios dump, original bios has flashed by other technician before me.
                attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                unit info:
                Model: Asus ExpertBook B1400CBA-0711A1235U
                S/N: R6NXNZ006657238
                CN: 7F6F
                Mainboard Code: B1500CBA R2.1...
                08-16-2025, 12:20 PM
