dell inspiron 1520 bios
  • rickybucalan
    • May 2013
    • 322
    • philippines
    i'm looking for bios bin for this model. DELL INSPIRON 1520.
    THANKS in advance.
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: dell inspiron 1520 bios
    Sorry, was gonna give the wrong model.
    • rickybucalan
      • May 2013
      • 322
      • philippines
      board model: DAFM5BMB6DO REV D:
      LAPTOP MODEL NO: PP22L
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        try this
        • rickybucalan
          • May 2013
          • 322
          • philippines
          try this
          thanks, but my bios file is 2mb.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Impossible, Dell inspiron 1520 bios is 1mb only-100% sure. Someone might have changed the chip. you try my dump with a new 1mb chip.
            • laptop repair house
              • Jun 2016
              • nepal
              THANKS in advance.
              ok
              • rockinho
                • Mar 2014
                • 13
                • Argentina
                that is wrong the dump is 2MB, model board DA0FM5MB8F0 Rev F check IC U14 SST25VF016B in schematic bye.
                • Bright IT Solution
                  • Sep 2016
                  • 12
                  • Bangladesh
                  Your file is ok i tried this and it worked
                  • zenius
                    by zenius
                    12-08-2024, 06:13 AM
                  • zlr8r
                    looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                    by zlr8r
                    looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                    cheers
                    Dell Inspiron 17 (7786) Laptop
                    Service Tag: 5J0NHT2
                    Bios: 1.9.0
                    MOBO: RO 15 17 WHL 2GB MB / 18706-2
                    Attached;
                    1. My saved bios using a programmer
                    2. Dells Bios updater .exe (v1.16)
                    3. Dells Bios recovery file
                    4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                    5. Image of ME...
                    12-18-2023, 03:08 PM
                  • mikeybass
                    by mikeybass
                    04-23-2025, 04:30 PM
                  • ngethin
                    DELL Inspiron 7415 (model in thread title edited) BIOS Needed Please!
                    by ngethin
                    Hey guys, I need help again please, if someone could be so kind as to help. Here are the details:
                    Model: Dell Inspiron 5410/5418
                    Service Tag: 1SNKP93
                    Motherboard: 36258772 Ver: 1A
                    Thank you!...
                    10-03-2024, 09:30 AM
                  • Litoh
                    Dell Inspiron 17 3793, FDI45 la-j091p bios
                    by Litoh
                    Нужна помощь: проблема с BIOS ноутбука Dell Inspiron 17 3793, FDI45 la-j091p (скорее всего после обновления windows). Нет инициализации. Реакция на кнопку есть, все напряжения поднимаются, кулер не крутится, индикация зарядки - горит белым. Родной дамп прилагаю. Нужен рабочий биос.
                    ENGLISH !
                    Need help: problem with the BIOS of the Dell Inspiron 17 3793, FDI45 la-j091p laptop (most likely after updating windows). No initialization. There is a reaction to the button, all voltages rise, the cooler does not spin, the charging indication is white. I am attaching the original dump....
                    01-07-2025, 05:54 AM
