here i share zed air sa bios
zed air sa working bios
Tags: None
Re: zed air sa working bios
@String2016
sir i did try to flash the bin file but i got no power. your file is w25q64bv which is i think a 3.3v spi while my iLife zed air sa is gd25lq64. a 1.8v spi. does this matter? or the system units is different?Comment
zed air reset bios configuration by clipping/short circuiting using a tweezer no.5, 6, 7 and 8 pins of a bios chip,. it works for meComment
ilife zed air sa
part no: 1406G.232was
mainboard id: ql-m e328832
chip id: GD25LQ64C_1.8VAttached FilesComment
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by SparklingxHi,
So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
now all... -
by BloodhoundjeHi everyone,
I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
I have desoldered the bios chip (GigaDevice...-
by titomno2Hi guys,
On motherboard ACER AN515-52 type LAF951P.
I fixed issue with not starting computer (it was the PQ201 component not working properly).
But after checking everything I have still an issue with secondary SATA connector JHD1 (for HDD typically).
Basically some HDD spin but are not detected by the bios.
Already tried following:
checked the 4 data lines
#2 RDSATA_PTX_C_DRX_P4 => CO18 (10nF seems OK) => RO24 (0Ohm measured at 0.25Ohms).
#3 RDSATA_PTX_C_DRX_N4 => CO17 (9.68nF seems OK) => RO23 (0Ohm measured...07-28-2024, 08:30 AM - Loading...
