zed air sa working bios
  • String2016
    • Nov 2015
    • 2240
    • philippines
    here i share zed air sa bios
  • sourcebf
    • Jul 2016
    • 433
    • N/A
    Re: zed air sa working bios
    thanks a lot
    • byulo
      ECT
      • Jun 2012
      • 94
      • Philippines
      Thank you paps.
      • mark_links
        • Oct 2017
        • 5
        • philippines
        hey bro what is the procedure but my keyboard and touch pad is disable and my usb port is not working how can i extract this file ty man
        • Romulo
          • Nov 2016
          • 484
          • Philippines
          reflashed the bios chip using external programmer i already tried above file and its working
          • mark_links
            • Oct 2017
            • 5
            • philippines
            ty sir
            • cimote_cs
              • Oct 2017
              • indonesia
              give me for tutorial please
              • cimote_cs
                • Oct 2017
                • indonesia
                give me for tutorial reflash bios please
                • eyob75
                  • Oct 2017
                  • Ethiopia
                  How can i use the zip file can you help me?
                  • nnoah
                    • Oct 2017
                    How do we use this file?
                    • String2016
                      • Nov 2015
                      • 2240
                      • philippines
                      reflashed the file using external programmer
                      • siklong73
                        • Sep 2014
                        • 6
                        • Philippines
                        @String2016
                        sir i did try to flash the bin file but i got no power. your file is w25q64bv which is i think a 3.3v spi while my iLife zed air sa is gd25lq64. a 1.8v spi. does this matter? or the system units is different?
                        • mojahiudul
                          • Nov 2017
                          • Bangladesh
                          Please Any one upload bios reset video by one ok zed air pro
                          • mojahiudul
                            • Nov 2017
                            • Bangladesh
                            If any one have a ok zed air pro than i can fix it by blind mode
                            • maky_tnx
                              • Mar 2018
                              • Philippines
                              can anyone solve this problem? please help.
                              • pankaj_moolrajani
                                • Mar 2018
                                • 5
                                • India
                                Thanks for providing the bios but it didn't worked in mine, can you please send me the bios for zed air IL.1406G.232WAS
                                • mahmoodgl
                                  • Feb 2015
                                  • 10
                                  • arak
                                  thanks
                                  • hillhoundz23
                                    • May 2018
                                    • Philippines
                                    zed air reset bios configuration by clipping/short circuiting using a tweezer no.5, 6, 7 and 8 pins of a bios chip,. it works for me
                                    • rayz009
                                      • Jun 2018
                                      • Philippines
                                      Sir can i Ask? Where can I find the pins 5-8 in the zed air laptop? I've tried to reset bios it but I cant find the cmos battery.
                                      • amr soliman
                                        • Oct 2015
                                        • 125
                                        • egypt
                                        ilife zed air sa
                                        part no: 1406G.232was
                                        mainboard id: ql-m e328832
                                        chip id: GD25LQ64C_1.8V
                                        • TyMercer
                                          Can I flash a working BIOS from one computer to another of the same make, model, etc?
                                          by TyMercer
                                          Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
                                          11-13-2025, 09:39 PM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • joven016
                                          Lenovo Ideapad S145 need working bios HELP!!
                                          by joven016
                                          Problem is blinking power led only
                                          i don't know exactly if it's s145-15igm or s145-14igm
                                          have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                          Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                          Already tested some of posted bios here
                                          S145-14igm - success but invalid serial and not booting on OS
                                          S145-15igm - success with serial and some other info in bios but still not booting on OS
                                          already tried installing new windows but always booting on bios setup
                                          windows installer flash drive detected on...
                                          08-21-2025, 10:55 PM
                                        • ngngocson113
                                          I need bios asus tp301u ( uma ( vga share))
                                          by ngngocson113
                                          hi everyone
                                          i need bios asus tp301uj ( "uma " vga share)
                                          my mainboard doesn't use vga chip and it uses vga together with cpu.
                                          I used some bios files (good).of the mainboard that uses vga chip. but can not turn on power.Meanwhile,its original bios file can turn on power But nothing on the screen
                                          thanks everyone....
                                          09-25-2025, 02:20 AM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
