zed air sa working bios
  • String2016
    • Nov 2015
    • 2238
    • philippines
    here i share zed air sa bios
  • sourcebf
    • Jul 2016
    • 431
    • N/A
    Re: zed air sa working bios
    thanks a lot
    • byulo
      ECT
      • 87
      • Philippines
      Thank you paps.
      • mark_links
        • Oct 2017
        • 5
        • philippines
        hey bro what is the procedure but my keyboard and touch pad is disable and my usb port is not working how can i extract this file ty man
        • Romulo
          • Nov 2016
          • 484
          • Philippines
          reflashed the bios chip using external programmer i already tried above file and its working
          • mark_links
            • Oct 2017
            • 5
            • philippines
            ty sir
            • cimote_cs
              • Oct 2017
              • indonesia
              give me for tutorial please
              • cimote_cs
                • Oct 2017
                • indonesia
                give me for tutorial reflash bios please
                • eyob75
                  • Oct 2017
                  • Ethiopia
                  How can i use the zip file can you help me?
                  • nnoah
                    • Oct 2017
                    How do we use this file?
                    • String2016
                      • Nov 2015
                      • 2238
                      • philippines
                      reflashed the file using external programmer
                      • siklong73
                        • Sep 2014
                        • 6
                        • Philippines
                        @String2016
                        sir i did try to flash the bin file but i got no power. your file is w25q64bv which is i think a 3.3v spi while my iLife zed air sa is gd25lq64. a 1.8v spi. does this matter? or the system units is different?
                        • mojahiudul
                          • Nov 2017
                          • Bangladesh
                          Please Any one upload bios reset video by one ok zed air pro
                          • mojahiudul
                            • Nov 2017
                            • Bangladesh
                            If any one have a ok zed air pro than i can fix it by blind mode
                            • maky_tnx
                              • Mar 2018
                              • Philippines
                              can anyone solve this problem? please help.
                              • pankaj_moolrajani
                                • Mar 2018
                                • 5
                                • India
                                Thanks for providing the bios but it didn't worked in mine, can you please send me the bios for zed air IL.1406G.232WAS
                                • mahmoodgl
                                  • Feb 2015
                                  • 10
                                  • arak
                                  thanks
                                  • hillhoundz23
                                    • May 2018
                                    • Philippines
                                    zed air reset bios configuration by clipping/short circuiting using a tweezer no.5, 6, 7 and 8 pins of a bios chip,. it works for me
                                    • rayz009
                                      • Jun 2018
                                      • Philippines
                                      Sir can i Ask? Where can I find the pins 5-8 in the zed air laptop? I've tried to reset bios it but I cant find the cmos battery.
                                      • amr soliman
                                        • Oct 2015
                                        • 120
                                        • egypt
                                        ilife zed air sa
                                        part no: 1406G.232was
                                        mainboard id: ql-m e328832
                                        chip id: GD25LQ64C_1.8V
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Sparklingx
                                          CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
                                          by Sparklingx
                                          So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
                                          So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
                                          now all...
                                          08-29-2024, 01:53 PM
                                        • Bloodhoundje
                                          HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                          by Bloodhoundje
                                          I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                          I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                          After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                          I have desoldered the bios chip (GigaDevice...
                                          03-16-2024, 03:12 PM
                                        • titomno2
                                          Acer AN515-52 SATA1 port not working no hdd detected in BIOS...
                                          by titomno2
                                          Hi guys,
                                          On motherboard ACER AN515-52 type LAF951P.
                                          I fixed issue with not starting computer (it was the PQ201 component not working properly).
                                          But after checking everything I have still an issue with secondary SATA connector JHD1 (for HDD typically).
                                          Basically some HDD spin but are not detected by the bios.
                                          Already tried following:
                                          checked the 4 data lines
                                          #2 RDSATA_PTX_C_DRX_P4 => CO18 (10nF seems OK) => RO24 (0Ohm measured at 0.25Ohms).
                                          #3 RDSATA_PTX_C_DRX_N4 => CO17 (9.68nF seems OK) => RO23 (0Ohm measured...
                                          07-28-2024, 08:30 AM
