Hp zbook 15 g2 bios flash
  • tronsdal
    • Sep 2019
    • 3
    • Norge
    Re: Hp zbook 15 g2 bios flash
    Hi
    I tried exporting the BIOS with a "Universal BIOS Backup Tool". Not sure if this is the right way of doing it, but if it is:
    Could someone please help me clean out the password from the file?
    I have attached the info about the laptop as well in a jpg
    Best regards
    Jo
    • peste
      • Dec 2016
      • 12748
      • ROMANIA
      Originally posted by tronsdal
      Hi
      Best regards
      Jo
      have you tried bios from the previous posts? if none works put the original bios here.
      • tronsdal
        • Sep 2019
        • 3
        • Norge
        Hi, thanks for replying.
        Yes, I've tried them using Win-key + b when booting, but the caps-lock light is flashing, the screen is black, and nthe fan eventuallyvstarts going really fast, but nothing happens. I uploaded my backed up bios in the previous post (but not sure if it is the right way of doing it with the tool, or if I have to use a chip reader)
        • perfm2
          • Nov 2019
          • 29
          • usa
          Has anyone had anyluck with this
          I've tried using the posted .bin files several different ways loading onto a USB key via the HP USB Bios updater tool
          Have the same issue as tronsdal
          If I use the M71_130.bin HP provides, the USB bios restore loads and works, but of course doesn't clear the bios password.
          Are these .bin's being posted only working if you flash the bios chip with an external flash programmer?
          HP sucks so hard for bricking their systems with the bios passwords being totally locked out
          • peste
            • Dec 2016
            • 12748
            • ROMANIA
            Yes, you need an external programmer.
            • ikaruga666
              • Jan 2020
              Can someone remove the password from my Bios?
              It is a ZBook 15 G2
              • peste
                • Dec 2016
                • 12748
                • ROMANIA
                #27
                try...
                • peste
                  • Dec 2016
                  • 12748
                  • ROMANIA
                  #28
                  try...
                  • ikaruga666
                    • Jan 2020
                    Thanks for the answer. I tested them both. The second bios works perfectly. Thanks, saved my day.
                    • daikav
                      • Jan 2020
                      • Lithuania
                      #30
                      Hi! Please remove bios password for HP ZBook 15 G2.
                      • peste
                        • Dec 2016
                        • 12748
                        • ROMANIA
                        #31
                        try...
                        • daikav
                          • Jan 2020
                          • Lithuania
                          #32
                          Wonderful!! Thanks!!! It is work. Maybe you knew this password? I lock my home server files with the same password. I forgot it.
                          Very thanks
                          • RethoricalCheese
                            • Mar 2013
                            • 1518
                            • Estonia
                            #33
                            It was password deletion, not decryption.
                            There might be a way to decrypt it but since it's bruteforcing, it might take years
                            • amr
                              • Apr 2017
                              • 5
                              • cairo
                              #34
                              5 plinking
                              • elbtonet
                                • Nov 2019
                                • 105
                                • albania
                                #35
                                Hi friends Ihave a zbook 15g2 and wont start up
                                it comes with black screen
                                please can anyone check my bios dump
                                i mthink is a bios problem
                                thanksss
                                • peste
                                  • Dec 2016
                                  • 12748
                                  • ROMANIA
                                  #36
                                  thanksss
                                  the copy of the posted bios is not ok ... make another copy of the laptop bios and post again..post the name and the complete model of the laptop and the motherboard model ..
                                  • nh85
                                    • Mar 2021
                                    • Slovakia
                                    #37
                                    Hi friends, can someone unlock me this password protected bios from Zbook15G2 25Q128FV?
                                    • ordinateur
                                      • Mar 2020
                                      • 81
                                      • Monaco
                                      #38
                                      Have a Zbook 15 G2 with BIOS password set on it. I can log onto Windows and everything but I wanted to clear the BIOS password forever. I managed to read the BIOS without desoldering via RT809H and the files seems to be OK as I explored it using HxD and everything seems intact. Can I just write one of the BIOSes above to check if the password has gone, or somebody need to help me by clearing this BIOS backups password ?
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1224
                                        • France
                                        #39
                                        try
                                        • ordinateur
                                          • Mar 2020
                                          • 81
                                          • Monaco
                                          #40
                                          Originally posted by Maxpower3
                                          try
                                          Done, it was fast, thanks you so much.
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • abhorsen
                                            Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                                            by abhorsen
                                            Hey guys,
                                            Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                                            Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                                            Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                                            07-06-2023, 10:22 AM
                                          • mrrubik
                                            Dell Optiplex 7010 micro bad BIOS flash?
                                            by mrrubik
                                            Hi folks,
                                            I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                            After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                            Steps I took:
                                            1. Read BIOS with CH341a, verified hash twice
                                            2. Patched
                                            12-23-2024, 04:11 PM
                                          • AkaBukai
                                            Is it okay to flash stock bios onto the motherboard's BIOS?
                                            by AkaBukai
                                            Hi there,
                                            I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                                            The little LED on the power button is flashing slowly and nothing happen.
                                            This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                                            So I decided to flash the BIOS using a cheap programmer.
                                            And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                                            I also...
                                            12-19-2024, 12:15 PM
                                          • James Jackson
                                            Panasonic CF-20G0247VM BIOS Bad Flash Help
                                            by James Jackson
                                            I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
                                            Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
                                            05-01-2025, 11:28 AM
