DELL 15 3537 La-9981p dump bios needed!
  • bergusz
    • Sep 2014
    • 19
    • Hungary
    Hi Everybody!
    La-9981p 8Mb BIOS needed. I cut a version from original and factory downloaded, but the notebook do the same:
    It powers up, but no boot and black screen, meanwhile It's beeping but doing it very slow and with some kind of echo after each beep!
    Maybe BIOS or ATI video fault!
    Thanx in advance!
  • imranromi
    • Jan 2015
    • 1290
    • Pakistan
    Re: DELL 15 3537 La-9981p dump bios needed!
    How many beep? If bios problem 1 beep
    TRY THIS IF SAME PROBLEM NOT BIOS ISSUE IF ATI GPU PROBLEM DISABLE TO ATI CHIP IF U NOT KNOW TO HOW TO CONVERT DIS TO UMA I SEND PICS HOW TO CONVERT FIRST TRY BIOS AND CHECK HOW MANY BEEP.
    • bergusz
      • Sep 2014
      • 19
      • Hungary
      Thank you very very much! I'll do a try on Monday and write a feedback!
      • bergusz
        • Sep 2014
        • 19
        • Hungary
        Unfortunatelly BIOS not solved it!
        Beeps are not usual beeps. It's one strong beep and then other 3 beeps which sounds like echo and on decreased volume. Little stop (2sec) and comes again the same, and it goes again and again continously. I don't think these are trouble codes.
        I'll try to warm the ATI a bit if it wants to come back to life... and then try a reball
        • anburaj.007
          • Apr 2017
          • INDIA
          Hi friend
          I am also have the same issue can you please send private msg for intel conversation..
          Many thanks. ...
          • imranromi
            • Jan 2015
            • 1290
            • Pakistan
            Here is.
            • lebana
              • Jan 2015
              • 81
              • sudy
              thank u
              • rmohacom
                • Jan 2015
                • 9
                • alger
                • kalamlaptop
                  • Nov 2016
                  • india
                  i have same problem i do bios but it wont turn on so pls help me and send how to do conversion
                  • kalamlaptop
                    • Nov 2016
                    • india
                    pls send the conversion detail i also have same problem
                    • mielta
                      • Apr 2015
                      • 368
                      look at the picture wich imranromi has send
                      • samanthban
                        • Feb 2014
                        • 253
                        • Sri lanka
                        Here is.
                        many times tried removing gfx power no luck but this work 100% Thanks Imranromi
                        sigpic
                        • hussaka
                          • Jan 2015
                          • 154
                          • italy
                          thank you
                          • ABDO26
                            • Jul 2019
                            • 14
                            • medea
                            thank you
                            • lapfix
                              • Mar 2020
                              • 2765
                              • my workshop
                              Imrani after removing PL802 still 8 beeps!..i change screen and screen cable too...still 8 beeps...any idea please !
                              a bios issue !! must be uma version !!
                              • huss584
                                Hussein
                                • Apr 2020
                                • 230
                                • Palestine
                                I have this bios chan please chek it
                                • canali
                                  • Oct 2014
                                  • 195
                                  • turkey
                                  thank you
                                  • zmezm1995`
                                    • Nov 2020
                                    • 99
                                    • iraq
                                    thank you
                                    • toufik sat
                                      • Feb 2016
                                      • 136
                                      • los angles
                                      • andrew25
                                        • Feb 2016
                                        • 224
                                        • Malawi
                                        mine has some same echo beeps... flashed bios not work, disabling gpu still same beeps...
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • TacticalFahrrad
                                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                          by TacticalFahrrad
                                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                          06-30-2025, 04:09 AM
                                        • vinaypundith
                                          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                          by vinaypundith
                                          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                          So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                          08-03-2024, 12:32 PM
                                        • James Maxwell
                                          HP DM1-4000er Bios Dump needed
                                          by James Maxwell
                                          I badly need bios dump for HP DM1-4000er,
                                          Model: HP DM1-4000er
                                          Motherboard: DA0NM9MB6D0 REV.D
                                          Product: QJ490EA#ACB
                                          Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                                          10-28-2024, 05:38 PM
                                        • mkdj
                                          by mkdj
                                          Dear all,
                                          10-19-2025, 04:41 AM
