Need Bios Acer E5-574G
Re: Need Bios Acer E5-574G
If you "search", you will find the correct bios for your laptopComment
Acer e5-574 bios
Motherboard : DA0ZRWMB6G0
REV : G
MODEL : ZRW
uma motherboard!
100% works!Attached FilesComment
Need help Acer F5-572G
Board: DA0ZRWMB6G0 Rev: G ZRW
Laptop was in Legacy Mode. Was turning on and working fine on battery. Was not booting on External power. If turned on on battery and after boot starts plug in Power cord, works fine (+ charging). Changed to UEFI - no problems starting on battery or power supply, woking fine. Changed to Legacy to backup files. Removed battery to insert SSD. After that the main problem.
Turns on, display turns on, but blank, nothing happening. Backed up bios by programmer and flashed other bioses for same board ID, non of them worked and all of them didn't turn on the screen. Just the original dump and the
W25Q64_CLEAN.zip by SMDFlea turn on screen, but stays blank.
I've attached my dump, seems like some BIOS issue, but can't figure it out.
All voltages measure OK. What else can I check?Attached FilesComment
Brand: Acer
Model: Aspire F5-572G
Motherboard: Quanta ZRW, DA0ZRWMB6G0 , Rev.: G, UMA version
CPU: Intel Core i5-6200U (SR2EY)
KBC: ITE IT8987E - CXA
BIOS:
U41: Winbond W25Q64FVSIG (64Mbit = 8MB)
Result - no screen, 0,22A current after power on. Fortunately I found working BIOS for this model on another forum. CheersComment
sorry..delete thatLast edited by peste; 02-19-2021, 08:04 AM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Not worked on:
Brand: Acer
BIOS:
Acer E 15 E5-574G-53C1 Bios
Can someone helpe me please? I need this bios.
cash code : Acer E 15 E5-574G-53C1
motherboard code : DA0ZRWMB6G0_rev_G
processor : intel i5 6200U
Gpu : Nvidia 920m
my backupAttached FilesComment
Re: Acer E 15 E5-574G-53C1 Bios
Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
by glovecapsHello,
The reason for wanting to do this is that the keyboard isn't working as it should, and I think this... -
by EbrahimSiamiHello everyone,
I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
**Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
**What I have tried so far:**
1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...-
Channel: BIOS Requests ONLY!
07-02-2025, 02:31 PM -
I am trying to fix an Acer Aspire 5542. Upon turning it on, the fan starts to spin for a few seconds and then it stops. I hear no beeps from the speaker. I have no image both on the laptop screen and through VGA and HDMI connectors.
I measured voltages, and it seems all power supplies are OK. There are 5V, 3.3V (BIOS), 1.8V (RAM), and 1.1V (VCORE).
I tried to read the BIOS using a CH341A programmer, but it did not detect the chip. I took the BIOS chip away from the motherboard, and then the CH341A detected the chip, and I was able to read the code. However,... -
by James194ztHi,
My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...-
by AmohacHi, I have an Acer Chromebook R753T
with administrator lock. Could something be done in the BIOS. Attached is the “BIN” backup.
Thank you.
Computer:
Acer Chromebook R753T-C1LK
Mother: DA0ZCAMB8D0 NETWORK: D
HSB J / 94V-0 / E89382 / 442 1/ MV-4
Bios: WINBOND 25Q128JVPM /2139/ M138/ 42300
16 MB
Serial NO: NXA8ZAA0031501A1A87600
SNID: 15010692076
Model NO: N20Q10
MFG Date: 2021/12/20....-
06-30-2025, 06:05 PM -
- Loading...
