ACER Aspire 5542 does not boot. Can not read BIOS on the motherboard
This topic has been answered.
  • fluzocapacitor
    • Jan 2024
    • 6
    • Spain
    I am trying to fix an Acer Aspire 5542. Upon turning it on, the fan starts to spin for a few seconds and then it stops. I hear no beeps from the speaker. I have no image both on the laptop screen and through VGA and HDMI connectors.
    I measured voltages, and it seems all power supplies are OK. There are 5V, 3.3V (BIOS), 1.8V (RAM), and 1.1V (VCORE).
    I tried to read the BIOS using a CH341A programmer, but it did not detect the chip. I took the BIOS chip away from the motherboard, and then the CH341A detected the chip, and I was able to read the code. However, no sooner did I put the chip on the motherboard (even without power), the CH341A stops detecting the chip.
    I checked all the BIOS pads on the motherboard, and I did not see any shortcuts.
    Could you please give me a hint to fix this laptop?
    Regards,
  • Answer selected by fluzocapacitor at 02-02-2024, 10:33 AM.
    Sephir0th
    • Oct 2020
    • 1289
    What you challenged is a absolutely normal behaviour. It is always strongly advised to remove the SPI flash from the motherboard when programming, since the interferences of the circuits may cause either not detecting or in worst case to read out a corrupted dump wothout realising it at all.
    • Sephir0th
      • Oct 2020
      • 1289
      FairRepair on YouTube
      • piernov
        • Jan 2016
        • 4439
        • France
        Possibly a bad RS880M anyway.
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • q2v5
          Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
          by q2v5
          Lenovo T480s
          Model 20L8-S3TE00
          Board ET481-U10
          Chip MX25L12873F
          Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
          2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
          The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
          08-15-2024, 10:40 PM
        • Max029
          Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
          by Max029
          I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
          I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
          TY,
          08-18-2024, 08:28 PM
        • futadmytro
          Asus g713qm-es94 stuck on boot bios problem
          by futadmytro
          sn^M4NRKD02753616E
          MB- g533-6050a3250201-MB-A03
          Stuck on boot after ROG logo, did not enter to bios
          In flash bios , laprop boot but have video issue
          orig bios...
          06-25-2025, 08:07 AM
        • oragano
          ASUS ex-b250-V7 motherboard bios corrupted - by me
          by oragano
          hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
          So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
          i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
          10-17-2024, 02:53 AM
