Problems: Laptop can turn on but no display. Already replaced RAM, test on external monitor still no display. No short circuit & overheating on motherboard. Any ideas? Thank you very much.
Need BIOS Dump For Laptop HP 15-ac AHL50/ABL52 LA-C701P Rev:1.0
Re: Need BIOS Dump For Laptop HP 15-ac126TU, AHL50/ABL52 LA-C701P Rev:1.0
Try this and reply.Attached FilesPremium supporters get full download access and other benefits.
try thisAttached FilesPremium supporters get full download access and other benefits.
Hi sancheti81. Unfortunately, your BIOS dump doesn't work for me. After flashing, the fan keep spinning for 2-3 seconds then stop. Is this BIOS problem or something else? If I'm using my BIOS dump, the fan keep spinning all the times.
Any idea?Last edited by Ikung; 06-25-2017, 09:26 PM.Comment
this is your biosAttached FilesPremium supporters get full download access and other benefits.
Im Back... sort of...
Hi ala_borbe. Thanks for the BIOS dump but it didn't work for my laptop. Fan keep spinning for 2-3 seconds then stopped. Maybe this is not a BIOS problem after all. Thanks again for your time ala_borbe..Last edited by Ikung; 06-27-2017, 09:16 PM.Comment
here
HP 15-ac022ur (Compal AHL50/ABL52 LA-C701P rev:1.0)
Techman1025Attached FilesPremium supporters get full download access and other benefits.
You sure? If there is only one chip then just flash it with the 8mb file . That's all is needed just double check
Techman1025Comment
I checked again this motherboard and it was only one chip. The BIOS dump didn't work for this model. When I press the power button, the fan keeps spinning for 2-3 seconds then it stopped. There is no short circuit and no overheating on this motherboard. All voltages are present. What else should I check?Comment
by mzk10kHello
I have model AHL50/abl52 LAC710p - ac120ns. It doesn't turn on after connecting the battery. The battery is charging correctly. I remove the battery, restart the bios by pressing the start button for 30 seconds without a charger and it works. I connect the battery, press the start button and it does nothing.
When it is on and I connect the battery, I reset it and it works and detects the battery.
I have measured some voltages according to the schematic and they are correct.
Can the BIOS be corrupted?... -
I have a motherboard from an HP laptop: AHL50/ABL52 LA-C701P. Idle consumption is 35 mA; when the power button is pressed, the consumption goes up to 85 mA and stays there for about 15 seconds, then returns to 35 mA at idle.
First observation: the UEFI chip is not powered (MX25L6473E). I've checked the schematic; the +3V_PCH seems to come from two MOSFETs, 2N7002 and AO3413L. However, I don't have either +3VALW or PCH_PWR-EN present. The PCH_PWR-EN comes from the EC (KB9022QD). I've tested the +3VALW_EC on a few pins and I have 3.3V on pins 22, 32, 47, 97, 98, etc.... -
by ZiliconHearty greetings to everyone, trust you all are doing excellently well.
Please, I have the above problem, the laptop turned on after the switch was activated but it will turns off in less than 2 seconds.
The power stables in very rare case. Once it was stabled, everything works fine.
Once the power switched is pressed, 5V and 3V were present.
The things i have done:
1. I have check for shorts on the board, but nothing. The board is short free
2. Not a power switch problem, it behaves the same without the switch ...06-10-2024, 05:05 AM -
by ramrkhi, i need bios for hp 15-ac122tu
MB Model : AHL50/ABL52 LA-C701P REV 1.0-
Channel: BIOS Requests ONLY!
- Loading...
