AHL50/abl52 LAC710p - ac120ns no power with battery connected
  • mzk10k
    • Apr 2024
    • Spain
    Hello
    I have model AHL50/abl52 LAC710p - ac120ns. It doesn't turn on after connecting the battery. The battery is charging correctly. I remove the battery, restart the bios by pressing the start button for 30 seconds without a charger and it works. I connect the battery, press the start button and it does nothing.
    When it is on and I connect the battery, I reset it and it works and detects the battery.
    I have measured some voltages according to the schematic and they are correct.​
    Can the BIOS be corrupted?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Very unlikely bios issue. You need to focus on charging IC,dc-in and discharge area.
    measure voltage on Gate-Source-Drain of dc-in mosfets
    All pins of charging IC with 01. only adapter connected 02. With battery+charger connected.
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • code share
      Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
      by code share
      I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
      Here's what I've tried so far:
      • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
      • Booted successfully on AC power only with the battery disconnected
      • Visual inspection of the battery — no swelling, burn marks, or connector damage
      • Battery
      04-21-2025, 12:50 PM
    • flat-earther
      how to prevent a connected charger from draining battery when not charging?
      by flat-earther
      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
      So the battery is backfeeding the charger and being drained.
      How can I prevent...
      08-07-2025, 01:04 PM
    • wraster
      Laptop stays on for only ~10sec when battery is connected, fine otherwise (Lenovo ThinkBook 15 G4 AMD)
      by wraster
      I have a Lenovo ThinkBook 15 G4 AMD (HLXB5 LA-M062P) that, when the battery is connected, starts up and shuts off in about 10 seconds, even when connected to power supply via USB-C charger. When the battery is disconnected, the computer stays on as in normal/expected operation (powered by USB-C charger input). I bought a new battery and see the exact same thing. My conclusion is it is not the battery itself but maybe some circuit or component involved in battery/DC-in crosstalk. I found a schematic but not boardview (request link below - sorry for the formatting, I'm not sure how to make an inline...
      Hi, I have a TB 15 Gen 4 that has an issue with the battery circuits. I believe the schematic is the same as this one: https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/schematic-requests-only/3522169-lenovo-thinkbook-14s-yoga-gen2-la-m062p
      02-25-2025, 11:33 PM
    • donnos
      A1989 820-00850 does not boot when battery is connected
      by donnos
      Hi All,
      have this macbook came in issues not able to turn on, found out the battery is blown(literally having holes in it). tried to do a battery swap and its still not booting up. However without battery connected, macbook boots up fine.
      Tried battery from another vendor, macbook boots but does not charge, system reports detects battery data and shows battery "service recommended". this at least tells me that the SMC/T2 is working.
      Tried changing ISL6240 chip and still the same. all 4 ports working fine,
      Checked current sensing resistors all...
      03-23-2023, 11:36 AM
