Need BIOS Dump For Laptop HP 15-ac AHL50/ABL52 LA-C701P Rev:1.0
Re: Need BIOS Dump For Laptop HP 15-ac126TU, AHL50/ABL52 LA-C701P Rev:1.0
Hello
Need Clean BIOS Damp
AttachedAttached FilesPremium supporters get full download access and other benefits.
Read the rules before posting..
.Comment
No,and i`m not your bro.There are enough working bios in this thread. If you have a backup post it,if you have the laptop serial number post it.
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
- Name your thread with model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific - black screen, no boot, running slow, password.
Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
Subscribe to support us. It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
HP Notebook - 15-ac024txAttached FilesPremium supporters get full download access and other benefits.
Virgin BID 080C1 bios with DMI offsets -> https://www.badcaps.net/forum/troubl...77#post1507977
"How to" guides:
[Guide] How to extract ready for programming dump from HP update executable file
https://www.badcaps.net/forum/showthread.php?t=121948
https://www.badcaps.net/forum/showth...51#post1261151
Hello !
I have a HP 15-ac148nf, AHL50/ABL52 LA-C701P Rev:1.0 that turns on but does not start.
Here is the SN: CND6494FV9
Here is the product ID: T8U02EA#ABF
Could I have confirmation that it is indeed the bios that is corrupted and if so, a dump of this corrected bios?
Thank you in advance !
you have everything you need for the post#6....use bios 080C1..Hello !
https://www.badcaps.net/forum/troubl...st#post1507977If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
by mzk10kHello
I have model AHL50/abl52 LAC710p - ac120ns. It doesn't turn on after connecting the battery. The battery is charging correctly. I remove the battery, restart the bios by pressing the start button for 30 seconds without a charger and it works. I connect the battery, press the start button and it does nothing.
When it is on and I connect the battery, I reset it and it works and detects the battery.
I have measured some voltages according to the schematic and they are correct.
Can the BIOS be corrupted?... -
I have a motherboard from an HP laptop: AHL50/ABL52 LA-C701P. Idle consumption is 35 mA; when the power button is pressed, the consumption goes up to 85 mA and stays there for about 15 seconds, then returns to 35 mA at idle.
First observation: the UEFI chip is not powered (MX25L6473E). I've checked the schematic; the +3V_PCH seems to come from two MOSFETs, 2N7002 and AO3413L. However, I don't have either +3VALW or PCH_PWR-EN present. The PCH_PWR-EN comes from the EC (KB9022QD). I've tested the +3VALW_EC on a few pins and I have 3.3V on pins 22, 32, 47, 97, 98, etc.... -
by ZiliconHearty greetings to everyone, trust you all are doing excellently well.
Please, I have the above problem, the laptop turned on after the switch was activated but it will turns off in less than 2 seconds.
The power stables in very rare case. Once it was stabled, everything works fine.
Once the power switched is pressed, 5V and 3V were present.
The things i have done:
1. I have check for shorts on the board, but nothing. The board is short free
2. Not a power switch problem, it behaves the same without the switch ...06-10-2024, 05:05 AM -
by ramrkhi, i need bios for hp 15-ac122tu
MB Model : AHL50/ABL52 LA-C701P REV 1.0-
Channel: BIOS Requests ONLY!
- Loading...
