Lenovo Yoga 500-15ISK BIOS or Battery charging chip
  • lagouzas
    Nemesis3
    • Oct 2013
    • 28
    • Greece
    Hello everybody. My problem is a dead Lenovo Yoga 500-15ISK just 2 months out of warranty. As of previous yoga models, this one had some charging problems for about a month and now it stopped working completely. When you place the ac adapter you can see a blinking led in battery and blinking keyboard backlight once every some seconds. Tried everything from peripherals and I am ensured that the problem comes from the motherboard. If anybody can split this bios file for me, I would appreciate that, and if anyone knows what's the charging IC chip on this motherboard (fru: 5B20K36401) it would help me. I have located 1275C chip but I don't know if this is the power controller.
    Seing is Believing
  • jeremykum
    • Feb 2012
    • 95
    • Malaysia
    Re: Lenovo Yoga 500-15ISK BIOS or Battery charging chip
    At this moment, don't offline flash those bios. Yoga and most of newer Lenovos uses MATCHED bioses for Main and EC. Different version, it won't startup. You could try backup the main bios. Refresh the Intel ME. Flash it back to the bios chip.
    Mainly repair laptops, sometimes LCD/LED monitors. Also accepts changing/reballing/reflow BGA job request.
    • Francisco.s
      • 686
      • Spain
      Have you tried to disconnect the battery and check if it works without it?
      • lagouzas
        Nemesis3
        • Oct 2013
        • 28
        • Greece
        Francisco.s that was one of the first things I' ve tried with no luck.... Unfortunately I had to pay to a local engineer to fix the motherboard.... motherboard is alive now.... battery is dead, it cannot charge at all. it must have drained too much power and burnt the charging circuit I think. I don't believe that this guy revived my laptop by refreshing the bios. Any fresh ideas? ( Motherboard doesn't seem any components changed, but as the components are removed with hot air, there shouldn't be anything visible )
        Seing is Believing
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
        • thxd43
          Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
          by thxd43
          Hello, first of all, excuse me, I am using the translator, English is not my native language.
          I have a Lenovo ideapad 330S - 14IKB laptop.
          The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
          02-23-2023, 08:37 PM
        • redbaron1007
          Looking for a way to read this bios chip. Lenovo Yoga 7 16arp8 bios chip.
          by redbaron1007
          I'm working on a lenovo yoga 7 16arp8 that had a bad charge port. When I replaced the port the laptops charge light will come on and stay on now, but when I push the power button the power light will come on for a couple seconds and then go right back out. I'm suspecting a bad bios, but when I went to read the bios to start the process of getting a new one it I found that none of my programmers will read the IC. I mainly use a T48 with Xgpro. I also have a ch341 and it's software that I use for ps5 uart and bios's, and a EZP2019+ and it's software.
          The chip is labeled MXIC MX77u2565ofz4142...
          10-02-2025, 12:51 PM
        • Rdd KEuns
          Lenovo X1 Yoga Gen5 Full Bios chip dump request.
          by Rdd KEuns
          Hello, My lenovo x1 yoga gen5 laptop has been unstable and sometime freezes. After downgrading the bios i was normal for a moment but when back to being unstable.
          If anyone has an working bios please share it.
          Laptop lenovo x1 yoga gen5. serial number PF-2MSZ9Q. Type number 20UC-S2410N. Motherboard model number GX4A0/GY650 NM-C881 Rev1.0. Bios chip GD25B256DYIG...
          03-21-2025, 05:49 AM
          Common SPI bios chip programming Questions and Answers
          by SMDFlea
          Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
          A: If you can`t read from it how do you expect to write to it ?.
          Q: Why is my bios chip unreadable ?.
          A: The programmer is faulty or has a worn or broken zif socket.
          The USB cable is frayed,connector pins worn or some other physical damage.
          Not enough amperage or voltage to power the programmer properly.
          Bad...
          09-02-2021, 04:40 PM
