Asus U47VC bios dump wanted
  • Mario
    • Sep 2007
    • 64
    here is the old bios file if anyone can rebuild or has a working dump?
    thanks
    it is a 3rd gen intel i5 model with nvidia graphics
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Asus U47VC bios dump wanted
    try this
    Im Back... sort of...
    • Mario
      • Sep 2007
      • 64
      thank you. works perfectly. How do you fix bios files?
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        with hex editor, update file from web site and a lot of experiments
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • pirati
          by pirati
          10-27-2025, 04:20 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
