HP Probook 450 G0 bios dump please
  • peste
    • Dec 2016
    • 12806
    • ROMANIA
    Re: HP Probook 450 G0 bios dump please
    sorry it looks like you used it ..
    • peste
      • Dec 2016
      • 12806
      • ROMANIA
      try..
      • kammy6000
        • Oct 2012
        • 22
        thankyou Peste ,yes that one was successful one time
        then i reflashed the same one , what i dont know is why the problem is persisting
        erase > flash
        i am using Bios Chip Programmer CH341A which has a chip grabber on it
        maybe the bioschip is faulty on motherboard?
        thanks
        • peste
          • Dec 2016
          • 12806
          • ROMANIA
          try bios from post # 22
          • kammy6000
            • Oct 2012
            • 22
            thankyou Peste i flashed another bios and is now booting and i installed latest bios from hp site . i had to put hardrive with with windows 10 on it already
            because the it wont detect any usb drive or dvd drive at all
            the usb ports are not working at all and the wifi not working and dvd drive not showing
            all drivers are installed its very odd
            i have enabled all options in bios to be ON i am now wonderign why the usb ports dont work they do not look damaged at all , 2 ports are 3.0 and 2 are 2.0 none of them work in windows or outside windows
            any ideas, thanks
            • canali
              • Oct 2014
              • 192
              • turkey
              #26
              • mouradreo34
                • Nov 2016
                • 3
                • algerie
                #27
                fiji MB 12238-1 48 4yz31.011 dump bios if you please.
                • danito
                  • Jun 2016
                  • 932
                  • Romania
                  #28
                  hp 450 g0 fiji MB 12238-1 48.4yz31.011 dump bios please.
                  I have 2 backups made with asprog and ch341a. None of them do anything after I put them on. Which give the error is when the LED flashes ii bag near the power supply, so.
                  • danito
                    • Jun 2016
                    • 932
                    • Romania
                    #29
                    nobody?
                    • peste
                      • Dec 2016
                      • 12806
                      • ROMANIA
                      #30
                      nobody?
                      try..
                      • danito
                        • Jun 2016
                        • 932
                        • Romania
                        #31
                        Originally posted by peste
                        try..
                        Thanks Over, resurrected. The problem solved as always.
                        • otechinfo
                          • Dec 2022
                          • 4
                          • algeria
                          #32
                          • otechinfo
                            • Dec 2022
                            • 4
                            • algeria
                            #33
                            can somebody post HP PROBOOK 450 G0 FiJi MB-12238-1 (48.4YZ33.011) bios dump please.
                            It would be very helpful for me.
                            Thanks.
                            • hardware1
                              • Sep 2021
                              • 2930
                              • N/A
                              #34
                              Thanks.
                              Upload your Original BIOS here, write your Device Serial Number and someone will try to help you.
                              all donations are welcome,
                              • carelaptop
                                • Oct 2023
                                • pakistan
                                #35
                                try this ok tested
                                • ianbak
                                  • Apr 2023
                                  • 52
                                  Attached is a dump of the BIOS from an HP 450 G0. Unfortunately it is password protected, so it would be much appreciated if someone could kindly return a copy with the password removed. Thanks!
                                  • peste
                                    • Dec 2016
                                    • 12806
                                    • ROMANIA
                                    #37
                                    read..https://www.badcaps.net/forum/troubl...before-posting
                                    • ianbak
                                      • Apr 2023
                                      • 52
                                      Thanks for the pointer, Peste - I was able to download RCUnlocker and clear the password myself. I much prefer to be self-sufficient!
                                      • mograinne
                                        • Jul 2015
                                        • 24
                                        • Slovakia
                                        #39
                                        Hello , I got HP 450 G0 S/N: 2CE33519GQ , can someone help me unlock MPM mode so I can update missing info with dmi tool? Everything else works fine. I was able to add SKU information trought editing dump but stil missing Product family and System Board CT Number I was unable to find them. Thanks for help in advance
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • studdy05
                                          Bricked HP Probook 450 G7 Bios questions
                                          by studdy05
                                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                          Ive got...
                                          07-08-2025, 09:24 PM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          Yesterday, 05:12 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • solomost
                                          need bios dump for HP ProBook 640 G2
                                          by solomost
                                          HI I need bios dump for HP ProBook 640 G2 PLZ☺☺
                                          prblm: black screen caps lock blinking 5 times then fan spening
                                          CT: PFKCT00WB69310 REV : 1.20
                                          motherboard : HSB J Mv-6 94v-0 E89382
                                          03-21-2025, 06:22 AM
