Hi, I need bios dump for this laptop ilife zed air. or someone knows the location where to reset the bios in the mainboard...
iLife Zed Air BIOS dump
Re: iLife Zed Air BIOS dump
Hey guys any solution to this Problem. I accidentally disable the Video GOP driver in the Setup utility and advance setting and now I don't see anything as the screen is completely black. I either need the steps (keyboard strokes) to do it re-enable the driver blindly, or do a cmos rest on the mobo. My laptop is i-life
Zed Air.
Would appreciate any help.
hi can you help me how to get back my lcd backlight of my zed air 14? it has display but no backlight it started when i accidentally short the red and black terminal of the battery then display went blankscreen but it has display if you point flashlight to the lcd i notice also the one ic labeled LP6253H became too hot so i remove it ,it has 2 pcs LP6253H my laptop still powering on and has display just the backlight went goneis it possible that the LP6253H is the cause?i cant find LP6253H to scrap boardcould anyone give me compatible ic to LP6253H? thanks
Originally posted by melody4net View Postthis is backup of working bios but keyboard +usb is not wok if u have asolution
Have you got any solution for this ?
Thanks for helping 😊
Originally posted by siklong73 View Postdisplay is ok. i changed bios settings and now keyboard, touchpad and even usb port are disabled.
can't find direct reset on mainboard. can't get into bios now because keyboard is disabled.
do you have a backup of this bios?
Please follow the instructions If keyboard or mouse not working in ZED series.
First you need to open the on-screen-keyboard from the ease of use menu.
Instruction:
1.Open run option from window bar and type regedit.
2.Go to HKEY_LOCAL_MACHINE
3.SYSTEM
4.CurrentControlSet
5.Services
6.i8042prt,
7.Start
8.Right click
9.Modify
10.Value data
Type 1
Ok
Exit
Restart PC
Originally posted by mcplslg123 View PostHERE IS THE SOLUTION for kbd ,mouse not working in zed air sa series.
Instruction:
3.SYSTEM
4.CurrentControlSet
5.Services
6.i8042prt,
7.Start
8.Right click
9.Modify
10.Value data
Type 1
Ok
Exit
Restart PC
