iLife Zed Air BIOS dump
  • siklong73
    • Sep 2014
    • 6
    • Philippines
    Hi, I need bios dump for this laptop ilife zed air. or someone knows the location where to reset the bios in the mainboard...
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: iLife Zed Air BIOS dump
    What is the problem?no display?
    • siklong73
      • Sep 2014
      • 6
      • Philippines
      display is ok. i changed bios settings and now keyboard, touchpad and even usb port are disabled.
      can't find direct reset on mainboard. can't get into bios now because keyboard is disabled.
      do you have a backup of this bios?
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        disconnect internal battery and take cmos bat and it should go back to default
        Im Back... sort of...
        • siklong73
          • Sep 2014
          • 6
          • Philippines
          thanks for the reply ala_borbe. but this zed air has no cmos bat. i already remove the internal battery for more than 24 hrs but still no luck. its mainboard is like a board of a tab. the cpu is intel atom quad core
          • mzerrouki
            • Oct 2013
            • Algeria
            Hi Siklong i've got the same problem did you find something to do with this mob before i open mine can you send me a photo of the mother board?
            • mzerrouki
              • Oct 2013
              • Algeria
              Hi ala_borbe have you got an idea about the chip location on this motherboard to reset the uefi bios to default? thanx in advance
              • String2016
                • Nov 2015
                • 2238
                • philippines
                Its hard to find the bios reset on this model.
                • nlepathy
                  • Jun 2017
                  • Seychelles
                  Hey guys any solution to this Problem. I accidentally disable the Video GOP driver in the Setup utility and advance setting and now I don't see anything as the screen is completely black. I either need the steps (keyboard strokes) to do it re-enable the driver blindly, or do a cmos rest on the mobo. My laptop is i-life
                  Zed Air.
                  Would appreciate any help.
                  • tom2000
                    • Sep 2017
                    • usa
                    Re: iLife Zed Air BIOS reset
                    I also have same problem Hey guys any solution to this Problem. I accidentally disable the Video GOP driver in the Setup utility and advance setting and now I don't see anything as the screen is completely black zed also dont have coms
                    • tom2000
                      • Sep 2017
                      • usa
                      Nelpathy did u find any solution
                      • String2016
                        • Nov 2015
                        • 2238
                        • philippines
                        hi try this
                        https://www.badcaps.net/forum/showth...hlight=zed+air
                        • hashim12atd
                          • Nov 2017
                          • Pakistan
                          yes, same problem here, I have no display, Video GOP disabled by mistake and no cannot see anything. Windows is corrupted as well. Can you give a guide me about this if you have solved or have an idea?
                          • ala_borbe
                            aka Donald
                            • 1625
                            • Malta
                            Can nay of you post backup ot that GOP disabled bios?
                            • melody4net
                              • 25
                              • egypt
                              this is backup of working bios but keyboard +usb is not wok if u have asolution
                              • walupapz
                                • May 2017
                                • 21
                                • philippines
                                hi can you help me how to get back my lcd backlight of my zed air 14? it has display but no backlight it started when i accidentally short the red and black terminal of the battery then display went blankscreen but it has display if you point flashlight to the lcd i notice also the one ic labeled LP6253H became too hot so i remove it ,it has 2 pcs LP6253H my laptop still powering on and has display just the backlight went goneis it possible that the LP6253H is the cause?i cant find LP6253H to scrap boardcould anyone give me compatible ic to LP6253H? thanks
                                • pankaj_moolrajani
                                  • Mar 2018
                                  • 5
                                  • India
                                  Hey i got the same problem ! Did you get any solution?
                                  • pankaj_moolrajani
                                    • Mar 2018
                                    • 5
                                    • India
                                    Thanks for providing the bios but it didn't worked my mouse and keyboard are not working !
                                    Have you got any solution for this ?
                                    Thanks for helping 😊
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      HERE IS THE SOLUTION for kbd ,mouse not working in zed air sa series.
                                      Please follow the instructions If keyboard or mouse not working in ZED series.
                                      First you need to open the on-screen-keyboard from the ease of use menu.
                                      Instruction:
                                      1.Open run option from window bar and type regedit.
                                      2.Go to HKEY_LOCAL_MACHINE
                                      3.SYSTEM
                                      4.CurrentControlSet
                                      5.Services
                                      6.i8042prt,
                                      7.Start
                                      8.Right click
                                      9.Modify
                                      10.Value data
                                      Type 1
                                      Ok
                                      Exit
                                      Restart PC
                                      • pankaj_moolrajani
                                        • Mar 2018
                                        • 5
                                        • India
                                        Instruction:
                                        3.SYSTEM
                                        4.CurrentControlSet
                                        5.Services
                                        6.i8042prt,
                                        7.Start
                                        8.Right click
                                        9.Modify
                                        10.Value data
                                        Type 1
                                        Ok
                                        Exit
                                        Restart PC
                                        How to open ease of menu without keyboard and mouse ?
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • EGUG
                                          Bios Dump for Fujitsu Esprimo D7010n with Mainboard D3823-A2 required
                                          by EGUG
                                          I have a Fujitsu PC with defective bios after bios update from Windows. Therfore I need a bios dump to fix it.
                                          Serial number EICK023345
                                          Mainboard D3823-A2
                                          Hope somebody can help me.
                                          04-10-2025, 02:05 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
