hi i need asus v551L BIOS plz
  • niggi
    • May 2016
    • 213
    • UAE
    hi i need bios asus v551L M/B number is S551LB MAIN BOARD REV 2.2 plz i need
  • cacla
    • Apr 2015
    • 444
    Re: hi i need asus v551L BIOS plz
    PLS sent me sn for this model
    • niggi
      • May 2016
      • 213
      • UAE
      model number ATHEROS/AR5B225
      • cacla
        • Apr 2015
        • 444
        No the serial number on laptop (this is located on sticker).BTW this is model on wi/fi.
        • cacla
          • Apr 2015
          • 444
          I found one here but i am not sure pls try this one
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            post your bios backup
            Im Back... sort of...
            • niggi
              • May 2016
              • 213
              • UAE
              thanks u so much bios is working
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • pirati
                by pirati
                10-27-2025, 04:20 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
              • lrouw84
                Asus vivobook s510ua bios changed to x510un
                by lrouw84
                Hi there,
                I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                01-28-2023, 01:31 PM
