Need BIOS rom file for Dell 7720
  • badfrog
    • May 2017
    • 4
    • England
    Could someone please extract me the rom file from this .exe
    (https://downloads.dell.com/FOLDER030.../1/7720A17.exe) as I cannot get it to extract on my other laptop as it is not a Dell laptop?
    My Dell 7720 requires the bios to be rewritten as it is corrupt.
    I can get it to look at the usb stick to load the rom file but as Dell only supply it as an exe file I cannot extract it.
    I have tried using '7720A17.exe -WriteRomFile' and it says it is going to do it but then stops without extracting the file (needs to run as administrator but even then it won't let me extract it).
    I would be most grateful if anyone with a 7720 could extract me the rom file.
    Thanks.
  • badfrog
    • May 2017
    • 4
    • England
    Re: Need BIOS rom file for Dell 7720
    Can anyone help before I give up on it and use it as a doorstop?
    • rioreno
      • Feb 2009
      • 540
      • Indonesia
      Thanks.
      check this
      http://forums.badcaps.net/forum/showthread.php?p=555427
      you can extract from 7720a17.exe but you will found only bios.cap, not full bios... no meregion,no descriptor region...only biosregion
      check this.. extract temp.zip
      • badfrog
        • May 2017
        • 4
        • England
        Thank you, I will let you know if I am able to revive it or not.
        Thanks again :-)
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          DA0R09MB6H1- Is This your Mobo code??
          If So then i have the dump
          • to5it0
            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
            by to5it0
            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
            I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
            This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
            I have opened the laptop and identified the main BIOS chip...
            10-24-2025, 01:35 AM
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • survivalbloke
            Unable to extract bios file from Lenovo bios exectuable
            by survivalbloke
            I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
            Code:
            "innoextract 7wcn38ww.exe"
            it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
            The trouble I'm having is that I'm not getting the newly...
            06-12-2024, 07:55 AM
          • survivalbloke
            Unable to extract Lenovo BIOS file from installer
            by survivalbloke
            I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
            I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
            How can...
            07-16-2025, 03:21 PM
          • Sathsul
            Dell Latitude 5431 issues with dumping bios
            by Sathsul
            So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
            The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
            However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
            10-28-2025, 07:49 AM
